larger crank pulley?
Old Jun 21, 2004 | 11:32 PM
Alvin@pcmforless.com's Avatar
Does anyone know where to find a larger diameter crank pulley for LT1's?
Old Jun 22, 2004 | 01:09 AM
Lisa33's Avatar
Depends on wich size you have? Think ATI has 6.45" and 7.65" for LT1 engines.
Old Jun 22, 2004 | 06:52 AM
IDOXLR8's Avatar
Re: larger crank pulley?
I know for a fact that ATI offers a 7.65 8-rib pulley and a 8.5 12-rib pulley. Your best bet may be to contact ASP. www.aspracing.com
Old Jun 22, 2004 | 04:27 PM
Where can you find these ati pulleys? do they replace the stocker?
Old Jun 23, 2004 | 06:05 AM
IDOXLR8's Avatar
You can buy the ATI pulleys straight from ATI. You will still have to run a balancer in conjunction with the crank pulley. Are you referring to blower crank pulley or balancer? I am a little confused on your question.
Old Jun 23, 2004 | 12:32 PM
My blower uses the stock crank pulley/balacer so i need something that would replace it only larger.
It could be a piggyback style like a underdrive
Old Jun 23, 2004 | 12:50 PM
IDOXLR8's Avatar
Oh ok I got you now.
I am not sure if any of the aftermarket balancers are larger in diameter than the stock one.
If you want to run an crank pulley specifically for your blower then you are going to have to run a spacer on your blower so everything lines up.
I know ATI (not Procharger ) makes aftermarket balancers.
Companies like ASP can custom make a crank pulley to your specification.
Old Jun 23, 2004 | 05:07 PM
humm.. Called asp today.. they will cut me one for $225. I've got to figure otu what size i want though.
Anyone have forsure measurements on the stock crank pulley diameter?
I think i'm giong to pully this thing up to 14pounds.
I'm thinking about making a custom chain drive for it.. that will be sweet
Old Jun 23, 2004 | 06:04 PM
IDOXLR8's Avatar
Wouldn't changing the blower pulley be easier than changing the crank pulley??
Old Jun 23, 2004 | 06:18 PM
stock lightning is 9lbs at 2.93
i just got a 2.7 but its only supposed to give you +2.5 lbs
94Form
Jul 17, 2015 10:56 PM
Bz8
Jul 13, 2015 04:46 PM
Rde Bandit
Mar 21, 2015 10:17 PM
