key or not?
Old Sep 16, 2003 | 05:47 AM
Lisa33's Avatar
key or not?
Hallo
Im installing a p1sc 6psi kit right now and have a little problem, When i did a cam swap erlier i noticed that there was no key on the crankshaft so now i wonder if i should remove the hub and install one (i think it was a splines in the hub) or can i skip it for now and install it later when its time to rebuild and turn up the boost.
Old Sep 16, 2003 | 05:55 AM
TimbrSS's Avatar
You should be fine with only 6psi on a stock motor. It would be a good Idea to key it when you up the boost.
Old Sep 16, 2003 | 06:10 AM
IDOXLR8's Avatar
Exactly what he said.
Old Sep 16, 2003 | 06:43 AM
Lisa33's Avatar
Thanks for a quick answer.
Thats what i tought, better to ask now or having trouble later.
Old Sep 16, 2003 | 08:51 PM
TonyJ's Avatar
The '95 doesn't have a keyway cut into the hub. Check out this thread:
http://web.camaross.com/forums/showt...63#post1334563
Old Sep 17, 2003 | 12:38 AM
Lisa33's Avatar
OK
i wasnt sure if there were a cut for the key in the hub, So now im pleased that i dont removed the hub just to find out that there was no cut in the hub
Old Sep 17, 2003 | 12:53 AM
TimbrSS's Avatar
I'm pretty sure all LT1's have the crank setup for a key. If you want to key the hub, you will have to have it machined for the key. I think thunder racing sells the hubs allready machined for around $70, or you can go to an aftermarket balancer like fluidampr or the ATI superdamper which come with a keyway machined in it.
68camaroboltz
Oct 5, 2015 11:56 PM
colts0455
Oct 4, 2015 09:47 PM
colts0455
Sep 27, 2015 01:07 PM
KYWes
Sep 26, 2015 08:49 AM
autoxr166
Sep 25, 2015 04:21 PM
