Ignition options
Old Feb 20, 2006 | 01:14 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
Ignition options
I am working on a friends car, its a YSi trim 383. We are expecting 850rwhp, and are looking at ignition options. I have never used an opti past 700rw, my personal car that made over 900rw, I ran a coil per cyl setup.
We had to gap the plugs down to .025 to get the thing to light off at high boost, even with a BTM-6
Those of you making ~800rw, what are you doing for ignition?
Old Feb 20, 2006 | 09:16 PM
engineermike's Avatar
Re: Ignition options
I've made 680 rwhp with an auto/loose converter using the stock Opti, MSD coil, and Crane HI-6. I've run it as high as 21 psi with no mis-fire. I think my plug gap is somewhere around .030".
I did have an ignition problem for a while - a severe backfire only at high boost. I replaced the old MSD coil with a new one and the problem went away totally.
Mike
Old Feb 20, 2006 | 11:14 PM
INTMD8's Avatar
From: I reached back like a pimp and smacked that LS1....
Stock opti, with riveted rotor contact
Stock coil
MSD Digital 6
Old Feb 20, 2006 | 11:51 PM
interesting. MSD said they were "not surprised' it blew the spark out with only a 6 series box.
Maybe I just need to keep the gap that small. I ran .035 on my coil per cyl setup with out fail, however.
Old Feb 21, 2006 | 12:19 PM
INTMD8's Avatar
Hmmm, Dan at work here also has a Dig 6 on his turbo 347ci SBF that made 1,020rwhp.
Old Feb 21, 2006 | 07:42 PM
So you know if the Digital 6 is "better" than the 6 bTM analog box?
Old Feb 21, 2006 | 09:26 PM
INTMD8's Avatar
I don't know for certain, but I believe they have the same output.
We run .032 on our cars fwiw. Not sure why you would be having a problem.
System voltage steady? Wiring/grounds good? What coil?
Old Feb 21, 2006 | 10:05 PM
MSD coil, grounds are (supposedly) good. I mean, car crank fine. I am going to replace the coil/head to chassis ground.
Old Feb 21, 2006 | 10:12 PM
INTMD8's Avatar
An easy thing to try would be swapping in a stock coil, I've had better results with stock than MSD's.
pimpen1024
Aug 19, 2015 08:36 PM
Aug 7, 2015 01:26 PM
Aug 5, 2015 08:35 AM
CARiD
Exhaust System
Aug 3, 2015 05:10 AM
RallyRed701/2
Jul 27, 2015 02:55 PM
