Idler Pulley - Locked
Subscribe
Jul 8, 2012 | 06:59 AM
Idler pulley locked up.....Looking for some advice/information.
Is this a standard pulley I can pick up locally, or is this an ATI part only??
My system is a P600
Thanks!!
Reply
Jul 9, 2012 | 12:27 AM
Re: Idler Pulley - Locked
You should be able to pick one up locally though you'll probably have to take the pulley in and find one that will work.
Reply
Jul 9, 2012 | 10:14 AM
Not sure on the Procharger but the Vortech is a stock Ford truck part.
Reply
Jul 16, 2012 | 06:18 AM
Solved!!!!.... Was able to remove the old bearings. They were a bitch to get out, but heating the pulley solved that. Picked up the new bearings from O'Rielly's for $12.00..... Much cheaper than buying a new puller from ATI!!
BTW..... the new bearings fit with no issues, so I will assume the bad bearings had something to do with the difficulties in the removal. I'm sure they got hot as hell.
Reply
Jul 16, 2012 | 03:22 PM
How about sharing a part # for the bearings, incase anyone else runs into this problem?
Congrats on the fix.
Mike
Reply
Jul 17, 2012 | 06:10 AM
sure can.... sorry I did not include that!!
The stock bearings - FAFNIR - # 203VV (two of them)
New bearings from O'Rielly's - National - # 203-FF (you will need two of them)
Thanks!!
Reply
Subscribe
