IAT Placement
Old Jan 29, 2008 | 03:34 PM
jchevy's Avatar
IAT Placement
Where are you guys putting your IATs? As close to the TB as possible? Are you somehow using the stock IAT or aftermarket?
Old Jan 29, 2008 | 05:02 PM
c0rey's Avatar
Placed mine in the same location as stock with a aftermarket screw in sensor.
Old Jan 29, 2008 | 07:25 PM
Boosted_Z28's Avatar
After speaking to Julio at Alkycontol (maker of alcohol injection kits) the other day, he got me thinking about mounting the AIT sensor in the actual intake manifold rather than the intake elbow as it more accurately senses the air temps that the cylinders are seeing, especially after the motor may become "heat soaked". Food for thought...
Old Jan 29, 2008 | 07:32 PM
subarubill96's Avatar
thats a great idea boosted, it gives actual correct info to the computer and considering your (OP) car is turbo, heak soak is a real concern especially if your placing the turbo were the air pump was which would put the stock location in the path of a lot of heat.
Old Jan 29, 2008 | 08:17 PM
jchevy's Avatar
Is there a certain sensor I neet to look for. Is it a part I can go down and get a napa or do I need to order it from an online vendor.
Vehicle it came from or part number would be great.
Old Jan 29, 2008 | 08:46 PM
re-use your stock sensor
Old Jan 29, 2008 | 08:48 PM
jchevy's Avatar
How? I think I have an extra, I might try to JB weld it or something into the metal elbow before the TB.
Old Jan 30, 2008 | 05:13 AM
ahahah i love jb weld too. just weld it into were ever your gonna put it and be done with it. you can get a bung from summit for a few bucks, just pick were you want it to be, cut the hole and weld it, screw it in and wire it up.
Old Jan 30, 2008 | 07:27 AM
jchevy's Avatar
The stock IAT sensor is plastic, so I cant use a threaded bung or weld it.
Old Jan 30, 2008 | 08:26 AM
jsetzer's Avatar
same
Old Jan 30, 2008 | 08:47 AM
jchevy's Avatar
What vehicles are you getting the sensors from? 80s camaro or gmc syclones? Do the plugs on the pig tails match?
Old Jan 30, 2008 | 08:58 AM
c0rey's Avatar
Syclone IAT screwed into a 02 sensor bung. Plugs match.
Old Jan 30, 2008 | 11:53 AM
CALL911's Avatar
Here's mine in my metal 90 elbow. The IAT sensor is in the upper left hand side of the pic with the black plastic tube sticking out of the side of the elbow. I am still using the stock one, and reccomend the same. You want it as close to the TB as you can get. Upstream of my IAT sensor you can see where my methanol injection nozzle is (bright orange/red line going into the elbow). You need to be aware that over time the methanol will corrode the IAT sensor, however it will take a while (even longer if you are on a 50/50 water meth mix like me), and the sensors are easy and inexpensive to pick up (can be found at Napa or Autozone for about $10).
Girrrrl
Aug 20, 2015 09:26 AM
Girrrrl
Aug 20, 2015 06:17 AM
Jun 6, 2015 08:27 AM
grabbem88
Feb 13, 2015 03:09 PM
rmount
Mar 20, 2003 12:19 PM
