i want to build an 800 horsepower smallblock
i want to build a supercharged l98 383 and want to get about 800 horsepower to compete with my friends mustang i searched and found go faststuff has an awesome deal on a rotating assembly http://cgi.ebay.com/ebaymotors/ws/eB...9720481&rd=1,1
i was thinking getting my block cleaned and notched and then assembled what would i need to get it around 800 hp such as cam heads supercharger intake i wanna go centrifugal and if its actually possible to do any of this
thanks
thanks
It can definately be done, there are a very few making around the 1000 RWHP with FI LT1's. I have yet to get mine on the dyno, but I suspect it makes somewhere in the nieghborhood of 550 rwhp and it cost me about 16 thousand to put together. I have no idea what your budget is, but I would expect it to cost at least 20k maybe more to achieve the 800 rwhp range. There are tons of hidden costs that pop up during builds like this, when I started I was estimating around 8 thousand for the entire build and it ended up costing double what I expected.
That rotating assembly is going to provide too much compression and not enough ringland thickness for the amount of boost you're going to need to run (especially if you're thinking about running on pump gas). If you're serious about making that kind of power I would highly recommend contacting one of the vendors on this board for a package deal.
would it be easier with a 355 or with nitrous and not a blower i want if for a street car so that i can spank everything in north jersey actually 650 700 would be good too if thats feasable
again, it's not too hard to make that kind of power, but when you're talking about winning races, you have to get that power to the ground. 650-800rwhp will more than likely just be good at creating smoke shows in the hands of an inexperienced driver or with a sub-optimal suspension setup.
What have you done to prepare the car for that kind of power? If nothing, expect it to be a $15-20k+ project including all the supporting mods. If you have that kind of funds, we can always help you spend the money and get you to your goal.
If you don't have that kinda cash up front, I'd suggest preparing for that power down the road by upgrading driveline and suspension parts first. You can certainly get more money for your stock parts when they are still functioning rather than throwing a bunch of power in now and replacing things as they break. That will give you more budget down the road.
A really good street combo is heads & cam plus N2O with a matched converter. Slightly higher compression with forged pistons will give you more room for spray.
The shorter stroke would allow your pistons to be thicker which is usually a good thing. Check out Speed Inc. They have built quite a few 800 hp combos.
If you're not familiar with how this stuff works, boost is simply a measure of restriction within the engine. If you pulley 2 of the same blowers with the same size pulleys, and put them on 2 different engines: 1)stock heads 2)ported aftermarket heads ; you'll wind up with setup #1 will make more boost and less horsepower than setup #2. The reason is that setup #2 is more efficient at moving air than setup #1, making it less of a restriction on the blower's outlet.
I wouldn't be upset that you have an auto. Sticks tend to lose boost in between shifts and an auto is defintely more consistant if you do go to the track.
