i want to build an 800 horsepower smallblock
also i was thinking if i were to build a 383 with nitrous how reliable would that be to be spraying a couple times a night as in just having the blower on the 355 wouldnt be as bad? or could a fully forged motor handle a 150 shot a couple times a night or even something bigger 200 250 300
alright so a nice 355 with a blower sounds good then ive been reading alot and is it true if i have a nice set of pistons and rods that the crank i can leave? that would save alot of money or would you suggest running the crank too
Building a 355 fully forged motor and a killer N20 kit $7,000
Building a 383 fully forged and a good Supercharger setup $14,000 +
(Niether is including everything else you need done to your car to handle the power)
BTW, I wouldn't say with even 650 RWHP you'll be able to spank everything in North Jersey. My car this year should easily attain that HP level, and I know of SEVERAL others in Jersey that would take me down like I was in reverse! To the barely or slightly modded, you would win no contest, however meet up with the highly modded guys, and you'd better be running a low 10 or faster to keep up.
Again, most anything out there you can probably spank with a 600 RWHP car. It's that last 5%, that care as much as you do, and have the highly modded stuff that you really have to worry about.
Any good speed shop will be able to give you a good run down of what the better internals to run are better than I could.
I went with all HIGH dollar stuff in my motor. But I also spent over $12,000 on the motor this last year AFTER I had already bought the 383 new for $8,000! I may have one of the more expensive motors out there, but I know my motor could take 25+#'s of boost just fine and just smile for more.
No, CR makes a difference. Although you are more likely to get away with spraying with a high CR when compared to running boost with high CR. If you spray with a higher CR, you can just get a timing control module and retard the timing so you can safely spray.
Either way, you are better off getting a lower CR though, for both boosted and N20 applications. If you want reliablity, you'll need to build a motor and get forged pistons anyway. You might as well just get some low CR ones while you're at it.
Motor for sell
OPies57,
I don't me to hi-jack the thread, but I have a pro-built fully forged supercharged 383 small block for sell that was in my 91 Z28. I sold the car as a roller and kept the motor. It has very low miles and needs to be sold because I have no use for it anymore. The engine is complete from supercharger to oil pan. I can save you a lot of money on a motor of this caliber.
730hp/ 700lb.trq on 100 octane with 9lbs. of boost (Vortech T-trim). With a Cola 4340 crank, Manley 4340 H-beam rods, JE pistons and ARP hardware this motor can handle more for sure. I do have all reciepts and spent around $12,000-$13,000 roughly, I will let it go for a whole lot less.
PM me for more details, build sheet and picture.
Thanks,
Dan
Thanks,
Dan
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
