I know...another cam question...
Old Mar 9, 2006 | 09:34 PM
77LT1's Avatar
Here's what I've got. I'm building a 9:1 all forged 383 LT1 engine with LE2 heads 58mm throttle body. I have a T56 tranny with 3.42 rear gears. Here's the problem....this is all going into a 1977 Camaro and my budget says I can only do the engine now and I have to do the Turbo later. I would like to ultimately make @ 650+ to the rear wheels but I don't want a dog of an engine until I can install the turbo. I guess I'll be driving the car for about a year until that happens. I've been told that a 224/224 571 lift on a 114 is a good choice for the power I want. The real question is, will this engine make some decent power without boost until I can get it there? If this isn't a good choice, what would be better for what I want to do and why.
I would really appreciate some advice on this as my head hurts right now trying to read all of this and make some sense of it. Thanks
Bryan
BTW This is NOT a daily driver but I want to drive it as much as possible when I get it running.
Old Mar 9, 2006 | 11:58 PM
engineermike's Avatar
Re: I know...another cam question...
That cam will be fine. If it were optimized for motor alone, you'd pick up maybe 15 hp.
Mike
Old Mar 10, 2006 | 12:13 AM
onlyone07's Avatar
I know where a 224/224 568/568 is at.
Old Mar 10, 2006 | 08:21 AM
77LT1's Avatar
Yeah, I guess I'll be calling you back and get that bumpstick from you..
Bryan
Old Mar 10, 2006 | 10:19 AM
onlyone07's Avatar
suhweet. still got my number?
Old Mar 11, 2006 | 01:02 PM
97WS6SCharged's Avatar
Bah, hum bug, buy some flanges and pipe and lets get to building some headers already.
Old Mar 12, 2006 | 10:02 AM
77LT1's Avatar
If you want to buy me everything I need, I'll be glad to weld it up. Welding is NOT the problem..... it's the $, always the $.
B
Old Mar 12, 2006 | 10:25 AM
LameRandomName's Avatar
Everything is always a compromise. If you're going to get a good deal on that cam and you are comfortable with it's specs, then get it. Frankly, it looks like it would work just fine with a 383 and LE2 heads and is actually a bit on the mild side. Not "grocery getter" mild mind you, just "hot rod" mild.
If and when you eventually get a turbocharger or supercharger and the manufacturer feels that you need a different cam, you can always do that and sell this cam one to offset the cost a few bucks.
And don't worry so much.
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
