I just ordered Dart Pro1 Heads
Old Mar 23, 2009 | 09:34 AM
Syl538's Avatar
Jegs has them for $543 each. Part number 11111111L. I called summit racing and they price matched them. $1080 pair. The only thing i dont like is the valve spring its a single spring: 1.25 O.D. and 110 seat pressure, .520 max lift.
Old Mar 23, 2009 | 10:54 AM
jay_rich's Avatar
Good price i just wish the comb chamber was a tad bigger.
Jay
Old Mar 23, 2009 | 01:25 PM
TA Dreaming's Avatar
Don't Comp 918s swap right on to these heads or no? You've peaked my interest as I had forgotten about these heads. They should make a pretty good budget head out of the box(minus the springs) for those like me wanting to make good power without going broke.
Old Mar 23, 2009 | 10:23 PM
blown94's Avatar
you can use these on LT1?
Old Mar 23, 2009 | 10:38 PM
reamo04's Avatar
if anybody is interested, SD has a deal for the dart 215?s and an edelbrock intake for 1600..... and the heads come with GOOD springs
Old Mar 24, 2009 | 09:24 AM
Syl538's Avatar
Yes, Dart Pro1 LT1/LT4 Heads http://www.dartheads.com/products/cy...ro1-heads.html
Old Mar 24, 2009 | 04:58 PM
boosted-lt1's Avatar
Not bad, but certainly can't be the cheapest way to get 257/170 cfm if you are running out of the box. I wonder what they flow at a more realistic 0.550".
Are you going to have them ported?
-Scott.
Old Mar 25, 2009 | 08:40 AM
blown94's Avatar
personally i dont see the benefit in these vs LE stage 2's with some better springs? if the combustion chamber was larger, then they would be a good choice for some, but my cnc ported stockers are 54 cc with 2.02 1.6 valves flow a little better. I think for a tad more you could do better, in my opinion.
Old Mar 25, 2009 | 11:18 AM
RUNMYTA's Avatar
I am running the Dart 180's and so far they are working really nice, especially for the price. I am still working out all the bugs with other issues, but I think they will do very well on a budget build. When I pop a head gasket or have to tear into them, I will send them to Lloyd to see how much more I can get from them..
Old Mar 26, 2009 | 12:06 PM
mkent's Avatar
I too am running the Darts. I was happy they have the small combustion chambers because I had already built my bottom end with the stock heads in mind. Had I bought heads at the same time as pistons, I may have atleast considered Trickflows or explored some of the other brands.
I'm also working out the bugs in my setup before I crank the boost and see what this turbo/heads setup will really do. Out of the box, the Darts looked very good and even had some bowl work from the manufacture. My only problem is that the Dart exhaust ports don't match my "D" port turbo manifolds very well. Hopefully that doesn't cause a huge flow disturbance
Old Mar 26, 2009 | 01:01 PM
1996camaroSSclone's Avatar
I went with trickflow for the bigger combustion chamber to get my CR lower.
Old Mar 26, 2009 | 01:08 PM
marshall93z's Avatar
Why didn't you just order them from Jegs?!
Old Mar 26, 2009 | 04:56 PM
Syl538's Avatar
I live in Cleveland 30 min away and i dont have to pay shipping and if there's a defect i can return them easily
Old Mar 27, 2009 | 08:28 PM
Ahhh....
Old Apr 1, 2009 | 01:42 PM
JAKEJR's Avatar
I've been seriously considering a set of 180s too for my son's 96 Vette and have been doing some research on them. Here's what I came up with so far:
GM HIGH PERFORMANCE TECH mag used them on a 355 CID build. They measured the ports and actually measured just a bit short of 190ccs. The entire article is posted on the GMHPT magazine. The 200s actually measured closer, at 200.7ccs
I've found these as the flow numbers. I forgot to write down who flowed them, but I believe it was AI and were as-cast:
61.2/48.1 129.1/93.6 176.2/124.3 221.7/153.4 250.6/171.5 259.5/179.1@.550 263.9/184.2 261.1/188.9@.650 256.5/192.1
Thanks much for the JEGS and Summit pricing. I was about to order a set from TPIS but I'd have paid $1,350. Guess who I'm going to call now, LOL.
Jake
West Point ROCKS!
