How's these specs for a turbo cam??
Old Mar 19, 2007 | 02:05 PM
detroit1994z28's Avatar
224/224 536/536 @114. Would this cam work good with my turbo system also will it sound more aggressive then my current cam which is the lt4 hot cam. Please let me know - Mike
Old Mar 19, 2007 | 02:58 PM
mkent's Avatar
Do you have the adv int/ex durations rather than the 224/244 @ .050 lift?
It is a general rule that you want minimal overlap on a turbo cam, however, there are people who seem to think it is not such a big deal. Corky Bell's book, MAXIMUM BOOST says:
"The characteristics of long duration and high overlap for atmo cams are unwelcome in a turbo system. The street turbo, which is generally small, operates with exhaust manifold pressure somewhat higher than intake boost pressure. This situation, when presented with long-duration, high-overlap cams, creates a huge amount of reversion. Thus the "turbo cam" tends to become a low-duration, very limited overlap cam."
I am guessing that cam has around +40* overlap. When I end up getting my custom grind, it will probably be somewhere between -8* and +8*....probably in the negative range because I'm using the factory log style manifolds so I expect the exhaust manifold pressure to be pretty high.
Old Mar 20, 2007 | 08:59 AM
RealQuick's Avatar
Originally Posted by detroit1994z28
224/244 536/536 @114. Would this cam work good with my turbo system also will it sound more aggressive then my current cam which is the lt4 hot cam. Please let me know - Mike
I think you meant 224/224 right?
Old Mar 20, 2007 | 09:37 AM
Thats right 224/224
LeftoverChinese
Jan 14, 2024 03:03 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
pimpss96
Feb 12, 2015 01:28 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Nov 20, 2014 06:03 PM
