How Much is Too Much HP?
Re: How Much is Too Much HP?
Originally Posted by 97WS6SCharged
Once you start getting above 500-600 rwhp, no street tire made is going to be able to handle the power. Look through some of the older posts and you'll read about people breaking street tires lose at 70+ mph.
Originally Posted by rskrause
I have pretty decent tires and can't use WOT in first or second. Third, sometimes depending on the road and the air.
Rich
Rich
Originally Posted by snorkelface
Ah crap. Maybe I could get an adjustable boost controller, and keep it at about 10PSI on the street? Any good alternatives besides that?
After my latest round of engine mods and the 373's, traction is sometimes hard to come by. Car will go sideways on occasion, so you have to be alert at all times.
It's a lot of fun driving my car around, but you have to be careful nowadays. The cops can confiscate your car if your caught street racing. Although I couldn't see them taking a ferrari from some rich guy, could you?
I was going to to step up my gears, but will now be leaving them with the 3.23's. It's funny that I'm actually kind of trying to make my car lazy.
So, what would be the latest in boost control? Anything that's pretty inexpensive that I could start off with?
I've just taken a quick glance through the topic so please ignore any repeated comments that i make but, if you want to auto cross the car then 900hp will be one big amount of overkill.I know guys who have built their cars for straight line only and are running 10 second 1/4 miles with about 650 hp.
With that being said,there are some local DSM guys that want to run in auto cross and they have BIG turbo's on their cars.The problem they are running into when they get onto the course is that they are never turning the engine fast enough to make enough boost to have any sort of power increase or advantage and they are only making in the 350hp range.I do realise that a V8 has alot more air flow than a 4cyl.So i know you will be building boost very quickly,probably to quickly for an auto cross track.
From: I reached back like a pimp and smacked that LS1....
Well, my car makes over 900rwhp at high boost, and my friends Cobra that makes over 1000rwhp (and in this months MM&FF), are both fine on the street if you're easy on the gas in 1st and 2nd.
If traction is a problem, just lower the boost, or adjust the ramp rate of the boost controller.
In fact, I think a few hundred HP more would still be good.
www.greddy.com
Check the PROFEC E-01. The load/gear boost is only available for certain types of cars (unless you're an electronics geek), but still, it's really neat.
http://www.turbosmart.com.au/boost_c...electronic.htm
More of a universal system.
where in alta loma do you live and what color is your SS? I'm over in north upland, I wanna see this thing when it's done, and see how much luck you have on the street with traction and cops.
i was right there two nights ago tearing around with open exhaust at about 1:30 am. I'll be on the lookout for your car, mine is teal, and i'm at Mountain, just S of the 210. anyways back on topic....
