How much HP would a twin T3 setup support?
Old Jan 25, 2004 | 09:05 PM
Serene's Avatar
Hey guys
Tried searching for some answers but you cant search under 3 letters
How much HP would a twin t3 turbo setup support? I'm not sure of what wheel trim and a/r yet, but if someone could give the max an average find of T3s would support, that would be great.
This is on a 383 btw
thanks
Old Jan 26, 2004 | 08:17 AM
mongse_1's Avatar
T3s are VERY small turbos. Somewhat popular on Hondas. On a 383, they would be way too small, even in a pair.
Old Jan 26, 2004 | 09:34 AM
Serene's Avatar
Thanks for the input!
How about T04B? 2 smaller turbos are cheaper than a single t76, not sure if that extra cost would be offset by the extra wastgate or not though....
Old Jan 26, 2004 | 07:49 PM
mongse_1's Avatar
I think a T04B would be much better. You will have to get an additional wastegate and BOV with twins, but you won't have to make a crossover pipe.
Old Jan 26, 2004 | 11:42 PM
RobZ's Avatar
Mongose what type of turbo you got on your car?Holset Hx35..
T04b's will support somwhere around 400 hp from what I have been told.
Old Jan 27, 2004 | 12:14 PM
mongse_1's Avatar
I could see a B making that much power without a problem, especially on a V8.
The big single pics were a joke to stir up some **** locally. It's a big ole Holset that was pulled off a commercial truck.
Twin T04S turbos are going on it at the end of the month.
Old Jan 27, 2004 | 03:32 PM
RobZ's Avatar
Old Jan 27, 2004 | 05:35 PM
mehoffz24's Avatar
quote
what does the A/R mean?
Old Jan 28, 2004 | 01:44 PM
mongse_1's Avatar
Maybe 500hp. They're a very small turbo. You can get them pretty cheap though ($200 or less on EBay). They're pretty common on small displacement 4/6-cylinder cars.
if you're ambitious, you may be able to find some used T04's for cheap. They came on some IHI(International) and Ford large commercial trucks. There's some good info to be found
here. *gasp* A Mustang board!?!
Old Jan 29, 2004 | 06:58 AM
neat's Avatar
A buddy of mine has twin T3 set-up on his 331 Mustang. He made 606 at the wheels. .60/.63 AR on both turbo's. He is thinking of going to a .82 housing though.
FWIW, I think a single would be a TON easier to do. I helped my buddy do the custom twin set-up on his Pusstang, and just one turbo would of made it a whole lot easier.
Try looking here for info on how to read a compressor map:
www.grapeaperacing.com
If it's not there, swing by your local libray and pick up "Maximum Boost" by Corky Bell. It's a good entry level turbo book. Once you know how to read a compressor map, and can figure the airflow of your engine, check out www.turbonetics.com for some popular turbo compressor maps. You should be able to figure out exactly what turbo(s) would suit you best.
brothaslide
Jan 9, 2016 12:11 PM
LeftoverChinese
Jul 23, 2015 03:57 PM
fundone2000-RZ
Pacific
Jul 21, 2015 07:21 AM
ducttape1975
Jul 10, 2015 06:29 PM
