How much HP will this
Old Jan 25, 2004 | 05:13 PM
BruceVette's Avatar
How much HP will a 255lph intank fuel pump along with Kenne Bell Boost A pump with the 50s injector can support???? this is with a stock fuel line
Bruce
Old Jan 25, 2004 | 05:47 PM
rskrause's Avatar
Moderator
Re: How much HP will this
Bruce
The injectors will be the "weak link". I saw 733rwhp with a 255lph intank, stock lines and regulator, and a BaP. I'd say that on a blower car you would be good for 500rwhp or so with 50's. Some people claim to make more with them though.
Rich Krause
Old Jan 25, 2004 | 05:51 PM
BruceVette's Avatar
Thanks Rich.
Also how do you deal with your high boost crankcase pressure?? Any tip is appreciated.
Bruce
Old Jan 25, 2004 | 05:55 PM
rskrause's Avatar
Moderator
Thanks Rich.
Bruce
I've been thinking about an evac system. But so far I am just using a breather on one of the valve covers. It annoys me 'cause it smokes a little after running hard.
Rich Krause
Old Jan 25, 2004 | 05:59 PM
BruceVette's Avatar
oh man. Look like everyone has the same problem with a little smoking after a hard run
Bruce
Old Jan 25, 2004 | 08:58 PM
engineermike's Avatar
Whew! I was getting a little worried about the oil that accumulates in the bottom of my hard intake pipe.
My valve cover vents there per stock Vortech instructions.
Mike
Old Jan 25, 2004 | 11:22 PM
marshall93z's Avatar
ive seen 550rwhp with that set up before on a good street tune...
seen 595 once but was a real crappy tune...that was dumping as much fuel as we could to try to get the a/f down, but it was lean so we quit.
but like rich said, the injectors are definitely the weak link!
Old Jan 26, 2004 | 09:08 AM
Chris B's Avatar
Same injectors but an upgraded fuel system (aeromotive 1000 series, new fuel feed/return) I've seen ~550 through an unlocked A4, with the injectors 100% maxxed (and leaning out around 6000rpm)
Chris
