How much boost with my setup??
Old Mar 27, 2009 | 10:19 PM
  #16
jay_rich's Avatar
Originally Posted by 94ttrim
also what about ARP head studs or bolts for what i plan on runnin, no more then 10psi. ive herd alot of leaking issues with studs and to the point i read alot staying away from them on a street car unless some serious boost. so there bolts shoud do fine for low psi? and is ARP rod bolts a must when doing compstars forged rods?
Leaking issues with ARP studs? That doesnt seem right. A stud applies consistent pressure unlike a bolt. I have had studs in my engine 2 years with no head gasket issues N/A and ALOT of WOT passes.
Jay
Old Mar 27, 2009 | 11:45 PM
  #17
1996camaroSSclone's Avatar
My compstar rods came with arp 2000 rod bolts from compstar.
Old Mar 28, 2009 | 07:37 AM
  #18
94ttrim's Avatar
i know ive done a good bit of searchin on studs vs bolts and it comes back with a good bit of issues of guys having leaking issues with the studs then anything, maybe cause there not using the right sealent or whatever but... ? and i wasnt even aware the rods came with ARP bolts, works for me!
Old Mar 29, 2009 | 07:11 AM
  #19
rtracy's Avatar
Ive heard the same about studs leaking also but it could very well be the sealant being used. I am starting my FI 383 build now and chose to go with the bolts not only do to the leaking issues but the ease of maintanance. I don't have alot of room under the hood to work. I also went with the ARP 2000 rod bolts. It is my understanding that they are a way better bolt.
Old Mar 29, 2009 | 01:47 PM
  #20
CALL911's Avatar
It's simple. If you've got everything apart, you are in a prime position to do things right (meaning safe for your engine and setup). Go with the ARP rod bolts, and definatly good call on lowering the CR. For 7-10#'s of boost 9-9.5:1 CR would be ideal. I am running around 15#'s of boost with my 8.8:1 CR, and honestly I feel totally safe if I wanted to boost my car up to 20+#'s of boost.
Definately read up, and keep asking guys on here that have the experience. You want to keep the rebuilds to a minimum. Thats why you do it right the first time and you don't have to worry about your car going boom any time soom under boost.
Henson071
Dec 30, 2015 09:55 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
