Head studs or bolts?
I was wondering how many of you +600hp turbo guys are running arp head bolts instead of studs. How much power/ boost can you make using bolts instead of studs? I would like to avoid the leaking stud issues if I can.
What is the leaking stud issue you are referring to? You put the same sealant on a stud that you would the bolt, and they both will seal fine. The stud is the way to go for clamping force (without stressing the head to threaded portion like a bolt).
We do have 5 bolts per cyl where the ls1 guys only have 4... that helps.
I run ARP BOLTS and was in the power range you are talking - I have run 5-7psi more than that since being on the dyno. No signs of leaking.
Also I run regular old felpro head gaskets.
If it matters I am in the upper 8:1 compression range too though.
Logs this morning show 19ish psi - Seen 23 a time or two, but that takes some really cold air and the wastegate never opening. Little 70 can't do that on a hot day.
Remember 19pounds on a t70 is vastly different than 19 on a 76+
figured id bring back a somewhat old post instead of starting another. i plan on staying in the 500ish WHP area, 10-12psi at most (down the road), prolly gonna stay more in the 7-9psi range. would i be better off going with the bolts or the studs?
