How much boost do you go up from 6# with a power pipe/solid intake tube???
Old Feb 17, 2003 | 02:08 PM
  #16
EDS Z28's Avatar
Hey Marc, thanks for that pn on the K&N. I looked at Brent's and your website, the difference being I'm running the twin intercooler setup, not a custom front mount. This will give me less room to work with, but I should be able to engineer something. The hard part is having it all solid pipe, that is a very tight radius coming out of the blower, it will be lots of cut and weld bends to make it happen. Possibly going down to 3 1/2" pipe will make it easier and should support the flow needed to the blower intake.
Old Feb 17, 2003 | 02:57 PM
  #17
Highlander's Avatar
PVC wont melt under the hood?????
Old Feb 17, 2003 | 04:55 PM
  #18
1st and goal's Avatar
There ya go
Nothing like some homeade engineering to suit your needs
With the twins you'll definatly have to snake it around but what the hell, might as well give it a try.
The K&N that I'm using is 4" opening by 12 total length. K&N does make a 9" with a 3½ opening, I think the part # is RE-0810 but you should check if you want a 3½ opening.
Good luck.
Marc
Old Feb 19, 2003 | 07:38 PM
  #19
Highlander's Avatar
Can someone post some sort of guide or pictures to what to get for a VORTECH intake tube???
Old Feb 21, 2003 | 06:53 PM
  #20
ironlung's Avatar
hmm, i didn't pick up anything on my car...well, before I got rid of it. Course I always had bad luck with cars...
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
XtremeLt1
Sep 13, 2002 08:50 PM
