How many PTK owner do we have in this site??
Old Jul 12, 2004 | 03:03 PM
  #46
JWBerk94Z's Avatar
Thanks Jose, that is really what I wanted to hear. Sounds like I might be one of the PTK owners on this site in about 6 months to a year. (I hope)
What is everyones take on A2A vs A2W? I talked to some friends of mine that spoke highly of A2W just as Highlander has.
Old Jul 12, 2004 | 03:05 PM
  #47
JZ 97 SS 1500's Avatar
I've said this many times, the A2W setup is just as good for daily driving, as long as you use a good heat exchanger. At the track its not contest. Drop some ice cubes in, and watch those IAT's drop.
Jose
Old Jul 12, 2004 | 08:22 PM
  #48
Highlander's Avatar
FINALLY... but some mechanical engineers disagree and say that air cools better JAJAJAJAJAJA then ask porsche why their cars are watercooled :P:P
Old Jul 12, 2004 | 09:09 PM
  #49
Hmm its widely known water has a much higher specific heat value than air. Heck air only has a specific heat value of 1.01 (at a CP), while water is 4.18. Basically for each degree increase, the same mass of water can absorb four times more energy than air. Their really should be no arguement as to which is better for cooling. Same principal as why we use liquid radiators and not air cooled engines.
Jose
Old Jul 12, 2004 | 09:27 PM
  #50
Highlander's Avatar
not to mention the density of water vs the density of air
Old Jul 13, 2004 | 12:12 AM
  #51
5.0THIS's Avatar
a good point, but remember, porsche made the air cooling thing work for years.... and it worked pretty good
Old Jul 13, 2004 | 12:51 AM
  #52
Highlander's Avatar
I know... hence why i brought them up... the best guys to know air cooling are in the water cooling now.. EVen PCs
Old Jul 14, 2004 | 10:16 AM
  #53
I plan to add a large front mount heat exchanger to my system. Will bascially look like a big A2A IC...hehe.
Jose
Old Jul 14, 2004 | 02:53 PM
  #54
Highlander's Avatar
Well i have a copper one that is about the size of 2 120mm PC fans... it has worked great in conjunction with the vortech.. but i will be making a better one copper.... that replaces it with my new kit...
I have a huge A2W now.
Old Jul 17, 2004 | 11:31 AM
  #55
Jason Dove's Avatar
I thought the problem with A2W is that the water can't disipate the heat that well after it's warmed up.
Old Jul 17, 2004 | 11:53 AM
  #56
No, it will dissipate heat just as quick. Do a search on heat exhangers on google, or yahoo. Their is tons of info and equations as well as lab report results from heating of water and cooling using the exhangers.
Jose
Old Jul 17, 2004 | 12:07 PM
  #57
Highlander's Avatar
The thing is that the mojority of the aftercooler systems are track setup... so they ONLY use ice and no radiator for ease of use...
Now.. the vortech unit comes with a radiator... and the only downside is that there is no fans (which i will adapt) to them... but still... Its no different than any other system...
The extreme Personal Computers use water cooling also
Old Jul 17, 2004 | 02:16 PM
  #58
Jason Dove's Avatar
Jose, where is the radiator or does it not come with one? I'm looking at your pic http://forcedinductions.com/images/ptk/PTK7.jpg
Old Jul 17, 2004 | 02:26 PM
  #59
It wasn't in that picture, since it and the fans arrived 1 day later.
http://www.forcedinductions.com/images/ptk/ptk8812.jpg
Jose
Old Jul 20, 2004 | 09:56 AM
  #60
Jason Dove's Avatar
Re: How many PTK owner do we have in this site??
Oh, the new fans go on the front of the rad instead of the back... interesting. I guess it needs the space for the head unit. I assume there's a second fan under the water radiator, can't see it in the picture.
Would you run some antifreeze in there for the winter?
