how many guys making 800+
Old Oct 20, 2008 | 02:19 PM
  #16
engineermike's Avatar
I too think that $4k is too cheap for a 1000 rwhp kit. Think about the fact that a good Procharger or Vortech kit goes for over $5k.
That said. . . I'm making 700 rwhp with an LT1 through an auto and loose converter. That's the equivalent of roughly 850 rwhp through an M6. The LT1 does have the advantage of an iron block (though a 4-bolt conversion is necessary) and 4 bolts/cylinder, but the disadvantage of poor flowing stock heads.
A while back, forcedinductions built a single turbo T76GTS LT1 with ported stock heads and 355 cid that made over 1000 rwhp at ~23 psi boost, though some have called BS on it.
Also worth noting is that the PT88 isn't a great choice. The compressor is efficient and matches a v-8 in the 350-400 cid range well, but the turbine is inefficient which increases backpressure and reduces power. A better choice would be an ST80.
Old Oct 20, 2008 | 02:32 PM
  #17
RealQuick's Avatar
Originally Posted by rskrause
There are reasons that there are so few street car based machines running 160mph in the quarter!
Rich
Rich, to run 160mph in the 1/4, how much power you need? Probably 1000-1100rwhp?
Old Oct 20, 2008 | 02:39 PM
  #18
rskrause's Avatar
Moderator
Obviously, the weight of the car plays into it and it needs to be able to hook. The 1/4m calculators aren't too accurate for really quick cars. But for a production based car like a Camaro, the OP is about right, ~1000rwhp is what you would need. My buddy's 5.0 Fox-body based car weighs ~3,100lbs and is back halved with a 4-link. He runs mid-150's with 900rwhp (through an efficient drivetrain).
Rich
Old Oct 20, 2008 | 07:57 PM
  #19
Funkybird's Avatar
I'm hoping to be very close to 800 as soon as I can make it bake to the dyno to do some more tuning.
Stock lt4 heads, intake, f1a 18-19psi stock pcm
I was having spark blow out issues but that is gone now.
Old Oct 26, 2008 | 08:36 AM
  #20
streetbad's Avatar
QUOTE=Funkybird;5571379] got my heads from scoggin dickey which are listed as LT4 CNC ported version 2 assembled and all it says about valve springs is diameter-1.320" and max lift-.525"
As far as I know thats what i'm running. I guess I better find out for sure!
Big difference Stock Lt4 vs. CNC ported
Old Oct 26, 2008 | 10:34 PM
  #21
sc68z28's Avatar
I always get the feeling when reading something like this that the OP does not have a good idea of what is involved in terms of time and cost building something like he is describing. There are reasons that there are so few street car based machines running 160mph in the quarter! And of the few that there are, most are not home built projects. They have had lots of professional help. Rich
X2, what Rich said.
I find this a rather odd thread, if I'm getting this right?
He does not care about the ET, just the MPH?
That's opposite my goal, I want to run high 8's and not exceed 150 mph.
---Bill.
PS, 800hp, pushing the limet with a 1st gen, GM, 010 block, splayed caps, O-rings. F1 Procharger, clutch car.
Old Oct 27, 2008 | 04:56 AM
  #22
rskrause's Avatar
Moderator
Originally Posted by sc68z28
X2, what Rich said.
---Bill.
Nice car! I bet you threw it together in a weekend?
Rich
Old Oct 28, 2008 | 09:21 PM
  #23
sc68z28's Avatar
Rich
Thanks Rich, I value your nod of approval.
Yes, just a bit longer than a weekend .
---Bill.
Old Oct 28, 2008 | 11:45 PM
  #24
T/A KID's Avatar
Yea I know what you guys mean, I put mine together in a weekend lol.
sc68z28 I seen you got a good clean pass the other day with that 140+mph trap speed .
Old Nov 13, 2008 | 11:49 AM
  #25
Daniel6718's Avatar
well **** a cam only ls1 with a 200 hit has gone 140+ my car went 137 with cam(gm hotcam)(stock heads) and 200 hit...
yes its a street car...i do want it to run good at the track but if you get the mph the et is easy...exspecially in an auto car...160mph is capable of 8.50 easy, id be happy with a 8.90, car will have irs which will be a huge obsticle
Old Nov 16, 2008 | 03:48 PM
  #26
subarubill96's Avatar
137 with a hotcam, stock heads and a 200 shot? wow, thats one strong running lt1
Old Nov 17, 2008 | 06:31 PM
  #27
does it end ?'s Avatar
Try looking in to the lQ9 block
Old Nov 18, 2008 | 08:53 AM
  #28
bad95formula's Avatar
A 200 shot on an LT1 with a stock bottom end???? Let me know how long that lasts for ya!!
Old Nov 18, 2008 | 10:31 AM
  #29
reamo04's Avatar
thats a 383, GT88 turbo. Jose at forcedinductions sent me that sheet when i was talking to him about potential of a gt88 on a 383 LT1. That was actually done with 25psi despite what the graph says.
Old Nov 18, 2008 | 10:56 AM
  #30
Verz's Avatar
He said ls1
but alot of very nice cars in here, def keeps me motivated.
