How high to spin boosted 383?
Old Jun 18, 2009 | 04:38 PM
LT1 POWR's Avatar
Will a 15-20psi forged 383 handle 7000+rpm? Will it continue to make good power up there if the valvetrain will handle it? I plan on upgrading to a LSX pcm so I'll have the ability to spin it to 8000 rpm if needed and just wanted to see if it would be a good idea. I figure my intake will make power up to about 9,000 and the heads flow in the 330's at .700 lift, don't know past that but if the motor will handle it, why not.
Pretty much I just want to know what rpm to set the rev limiter at and where to have the blower max out at?
Anyone done this? Lets hear some good reasons as to why this would be a good/bad idea.
Old Jun 18, 2009 | 05:45 PM
boosted-lt1's Avatar
Well, you should pulley the blower to max out at peak HP which will be functions of heads and cam.
7K is 7K. 7000 on a 450 hp motor will impose most of the loads on the internals as 7000 on a 700 hp motor.
Old Jun 18, 2009 | 08:51 PM
crazycat's Avatar
what heads do you have that flow that much ? I have the same forged 383 that iam just getting broke in , I think I will go to about 7000 rpm. I will have it on the dyno in a few weeks and see where the power starts to drop off.
Old Jun 19, 2009 | 12:21 AM
ak95ta's Avatar
Exactly, a reason would be that you have already made max power and torque at let's say 6000, there wuld be no need to spin it any higher. Get it on a dyno and see where max power and torque is. If it is at 8500 and your engine is build for it, sure spin it up that high.
Old Jun 19, 2009 | 08:48 AM
slomarao's Avatar
What bottom end parts are you planning on using?
Is this an all out race engine?
7k+ is a lot of rpms with 15psi. 20psi is a ton, are you running a solid roller cam??
Old Jun 21, 2009 | 08:39 PM
4SFEDZ's Avatar
put it on a dyno and see where the power is, cam will have a big part in it as well
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
drptop70ss
Mar 26, 2015 01:50 AM
D1SC383LT4
Jan 26, 2015 01:41 PM
