How is everyones car coming along this season??
Originally posted by Guido
Pulled engine to change flywheel and add rev kit. Engine is back in but rev kit should be here today. Get that in and Ill be back to the track. Then Im going to add the other parts I have sitting around which include:
wilwood discs for front
coil over conversion
tubular a-arms
wolfe sway bar
QA1 12 way for back
new springs for back
Hope to get this thing into the low 9 range this season.
tubular a-arms
wolfe sway bar
QA1 12 way for back
There are plenty of Stage II V6 Buick TRs in the 8's with a single 3-bolt 88mm turbo and you have two more cylinders and a lot more cubes so I think 8's shouldn't be a problem or if the traction isn't there (60' times aren't up to par) you should at least see the MPH (well over 150mph in the 1/4) with about 20-30lbs of boost!!! BTW, how much does your car weigh??
Roughly 3300 pounds.
I HOPE it gets 8's but Im not going to get my hopes up yet. LOL
I plan on running 20+ psi on this thing so I know it will go.
Hey I have one run on it so far and its 10.95 @ 126 with 5 psi of boost and a shoddy 1.67 60'.
Sounds good Guido! At 3300lbs and with the boost turned up in the 20+ range you should definitely be hauling the mail and if you can get a 1.3 60' those 8's should be on the board
FWIW, I was at the local track down here (Moroso) and saw a 3200-3000lb '68 Camaro with a single turbo (PT-88) low buck fuel injected SBC (355ci 4-bolt main block, Brodix track 1 heads, custom headers, Accufab 90mm TB, FAST/Felpro sytem, 2-speed PG, etc.) run 5.91 @124mph in the 1/8th with only 20lbs of boost and he will be looking for the 8's next time out with around 30lbs of boost
Here is his website.... http://www.chiseledperformance.net
Yeah when I spoke with them at the track they were very cool!
They told me about the trouble they were having finding the right converter for the combo (think they said they have used like 4 or 5 different converters).... The motor setup is pretty low buck, but very nice with his custom headers (which I thought looked great) and that car from what they told me has the potential to 60' very well cause with a BBC and N20 it was getting 1.28 60's off the trans-brake!!!
I love hearing that car at the line spooling and last time out with him leaving off the foot brake he spanked a pretty nasty N20 small block Stang
Once my stuff comes in from Precision Turbo next week, I should be in the clear. Of course, I have to get it tuned first.
I would've been done by now if I hadn't been dicked around on cylinder head work. :\
I'm waiting on my ProTurbo kit to arrive. Should be here middle of next week or so. Then I will have to finish routing the fuel lines and installing the FAST. Then its time to crank and dyno....we'll see
Jose
Jose
coated headers, supercharger and another $1000.00 dollars of misc parts going on the IROC this weekend. It won't be that fast maybe mid 11.5 or so. It will hold it own agains 75% of the cars out there.
Bruce at Aggressive is a good guy. Bruce put my motor together when I was in the hospital so I could make the last track event a couple of years ago. Tell him Chris said hi and that I am still alive. I will have to go by there next week and show him the new setup.
Engine is at the machine shop now. All the following is supposed to be finished by the beginning of May:
Engine:
355 Forged LT1 .030 Bore-Over
Forged Eagle Crank 4340, 1-piece Seal, 3.48 Stroke, 2.100 Rod Journals
Forged Ross Pistons
Forged H-Beam Rods
Dynamic Internal Balance
High Volume Oil Pump/Pickup
Splayed 4-bolt Main Caps
Clevite H Bearings
Sealed Power Rings
Fel-pro Gaskets
Full Blue-Print
Heads:
CNC Ported and Polished Stage III Heads, 64cc Chambers
ARP 6 Point Head Studs
Custom Ground Camshaft
Hardened Push Rods
Crane Gold 1.6 Roller Rockers
ARP Rocker Studs
Roller Lifters
Hydra Rev Kit
New Timing Chain
NGK Plugs
Lucas 42Lb/Hr Injectors
Supercharger:
D1-SC Supercharger w/Twin Intercoolers, Inline Fuel Pump
Other:
1 Day of Dyno tuning
Moser 12 Bolt 33 Spline Posi w/ABS
High Performance 4L60E Transmission Rebuild
Wolfevert 4 Point Roll Cage
Autometer Electric Fuel Pressure Gauge
Autometer Manual Boost Gauge
Autometer Dual Gage Pillar Pod
I've already got the suspension stuff done and a 3200 stall, longtubes, etc...
Engine:
Forged Ross Pistons
Forged H-Beam Rods
Clevite H Bearings
Sealed Power Rings
Fel-pro Gaskets
Full Blue-Print
Heads:
Hardened Push Rods
ARP Rocker Studs
Roller Lifters
Hydra Rev Kit
New Timing Chain
NGK Plugs
Supercharger:
Other:
i'm all about budget baby.....i have maybe $1500 into my shortblock and i bet i dont ever break it.
i plan to try and make some money back at the street racing events in my area so i wont be posting times anytime soon but once summer is over i will
