Quote:
Probably more like 400.Originally Posted by axehead
isn't xxsaint getting 697rwhp? couldn't he add a 300 shot of spray to that combo & get real close?
I'm making 700 rwhp also, and would never think of putting a shot that big on mine. That's one of those things that's 100x easier said than done.
Mike
Quote:
Rich
Rich- I realize there is not much to compare between ethanol (E-85) and methanol. I was just pointing out that there are some nice gains (and benefits) to running methanol vs. leaded race gas (118 octane) and would have to believe on a smaller scale that E-85 would offer some performance gains compared to unleaded premium. I'm looking at this from a purely performance aspect and obviously factoring out the additional fuel consumption/mileage disadvantage that it carries.Originally Posted by rskrause
Ethanol has a lot less hp potential than methanol. The cooling effect is not as pronounced and the energy content of an equivalent mixture is much less. E85 may be one up on gas though, and you can get it at the pump (in certain parts of the country). Rich
One BIG reason why we use E85 is fuel price.
pump gas = 7$/gallon
Race gas = 24$/gallon
E85 = 5$gallon
(E85 is avalible at almost every station)
Aboute 300-400hp N2O shots, Beacuse of the higher octan from pure E85 we will step up to 150hp N2O this season, We will do a test widh 125 first. 300-400 No way, if we need more HP we proberbly go widh a big turbo or two
The biggest worries about turbos is lag, since we are race only we need a lot of boost direct from start so if someone have good advice about wich turbo/s or company to choose please write or PM.
E85 = 5$gallon
The biggest worries about turbos is lag, since we are race only we need a lot of boost direct from start so if someone have good advice about wich turbo/s or company to choose please write or PM.Registered User
I believe that by choosing the right turbo for the application, lag is all but eliminated. Others may post up to help clarify the "lag" issue. A lot of turbo guys here leave on a type of two-step, allowing them to spool up the turbo to some good boost numbers before launching the car and they leave like a rocketship. Hate to think you may "go to the dark side" by switching to a turbo at some point, but if you found the right turbo(s) for your application, I'm sure you would continue to see performance gains.
Moderator
RPM won't spool up a converter, it has to be under load. This is one reason why all serious drag cars wtih turbos have automatics. They load the motor against the brake to prodice high volume/velocity of exhaust gasses and spool up the turbine. The fastest local turbo car has a godawful huge blower and it takes it about 5 seconds in the pre-stage to get it spooled up. Sounds like a jet warming up. I am not generally a fan of tuirbos (no pun) but that whole procedure is kinda neat.
Rich
Rich
Yea have sean a lot of turbo cars that have to spoole up in allready in prestage, the problem is that we have a lot of racers that takes advantage of that and do everything to ****up the spool time for them, its real fun to see a non turbo guys waaaaiting to be second in prestage and after that roll in to stage direct, many of the turbo guys makes fine times in the qaulifiction but when its headsup racing theres anotherthing, Its hard to be sucessfull true a 32 car ladder...
Moderator
Quote:
Gee, I would never do that Originally Posted by Lisa33
Rich
Mike
roguedriver is making 808rwhp with a 150 shot, a 300 shot would put him at about 981. that's a lot of power!Originally Posted by engineermike
Probably more like 400.I'm making 700 rwhp also, and would never think of putting a shot that big on mine. That's one of those things that's 100x easier said than done.
Mike
Quote:
Have you ever sprayed a car or had a high HP car? I don't know that even c16 would be enough for that. 300+ shot on top of a blower setup is A LOT.Originally Posted by axehead
Moderator
I run up to a 200hp shot or a bit more with 24psi on 100 octane unleaded with water injection. CR is 7.8:1 though. The heads aren't that great, so the 24psi is a little misleading though.
Rich
Rich
Quote:
Rich
I love your posts, because you put in important information like the last line. Originally Posted by rskrause
I run up to a 200hp shot or a bit more with 24psi on 100 octane unleaded with water injection. CR is 7.8:1 though. The heads aren't that great, so the 24psi is a little misleading though.Rich
I doubt you were anywhere near 1000rwhp though either.
Moderator
Only 818 on this run. That's with a 100hp shot, never ran it with 200 on the dyno.Originally Posted by 1982z28with18s
You have twin fuel pumps? I knew you made 700+ on the 255/boost a pump, I never knew you stepped it up though.
