Is a hot cam ok for a supercharged car?
Old May 8, 2004 | 10:11 AM
  #31
Highlander's Avatar
Originally posted by steve10358
If you are going to go through the trouble of swapping cams...why waste your time by going with a Hotcam? Why not get the best cam you can?
Seems kinda obvious to me.
That is exactly what we are trying to determine.
Old May 8, 2004 | 12:57 PM
  #32
RCF925's Avatar
For what it's worth I'm pretty happy with a custom cam I had ground for my 385. I'm still doing some tuning on it and have not pullied up yet and so am at 5psi boost. The grind I used is 228/236 510/525 113lsa +2. This has a nice lopy idle and will make power to 7000 rpm and beyond. I ran my combo on a desktop dyno figuring 8psi and came up with 680fwhp. Right now I'm at about 540 rwhp so the numbers should be close to what I figured before building it. I also looked on the board here at everybody using similar cams for blown applications, but in the end went with what my engine buider recomended when doing the shortblock.
Old May 8, 2004 | 02:35 PM
  #33
Highlander's Avatar
its a very similar cam to the ones we are discussing... maybe too much overlap... I am going with a 116 lsa this time... same duration more lift.
Old May 25, 2004 | 08:34 PM
  #34
95TALT1's Avatar
with good springs what is the highest lift you can run on a stock lt1 bottom end just wondering cause i am new to the lt1 im an old pontiac man
Old May 25, 2004 | 08:52 PM
  #35
engineermike's Avatar
I'm not sure why the bottom-end would matter.
Max lift is more a function of valvespring choice, set-up height, retainer/valve seal clearance, and lifter type.
I don't generally recommend over .600" with a hydraulic cam because the open spring pressures get over 400 lb which could compress the lifter at low rpm and shorten their lives. You have to carefully set up the valvetrain to reach .600".
With a solid roller, the sky's the limit. How long [or short] do you want your springs to live? It seems like .650" - .670" can be made reasonably reliable.
Mike
Old May 27, 2004 | 01:48 AM
  #36
carnutz's Avatar
I think he is asking Piston to valve wise....I think the answer still right around .600 with out pulling the head and claying it....
Old May 27, 2004 | 06:26 AM
  #37
Piston-to-valve clearance is dependant on duration, LSA, and advance, NOT max lift.
Mike
Old May 27, 2004 | 12:27 PM
  #38
95TALT1's Avatar
hey mike what might those be
Old May 27, 2004 | 04:56 PM
  #39
Duration, as in intake and exhaust duration of the cam: more duration means less clearance.
LSA as in lobe separation angle: smaller LSA's mean less clearance.
Advance as in cam advance: generally higher numbers (positive or negative) will have less clearance.
Mike
Old Aug 31, 2004 | 03:58 PM
  #40
Highlander's Avatar
Re: Is a hot cam ok for a supercharged car?
I might add that Bret did choose the 12º exhaust duration over the intake on my cam?
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
Queens94z28
Dec 20, 2014 09:11 PM
USAirman93
Nov 24, 2014 03:37 PM
Queens94z28
Nov 20, 2014 06:03 PM
GigaMp3z
Feb 20, 2003 02:57 PM
