High Octane
Old Jul 30, 2006 | 10:35 AM
ChrisUlrich's Avatar
High Octane
If you are running 20psi. You throw in higher octane (IE: 100, 118, etc...) but don't turn the boost up. Will the car have any increased performance? I am under the impression that it won't do anything for the car.
Old Jul 30, 2006 | 11:09 AM
Sparkz28ss's Avatar
Re: High Octane
if you have no detination then no.....
the higher the octane the slower the burn rate and the less btu's per gram
Old Aug 6, 2006 | 04:24 PM
Lisa33's Avatar
Re: High Octane
If you have retard youre timing to avoid detonations and turn it up widh racefuel you gonna gain HP.
Old Aug 9, 2006 | 10:50 AM
Re: High Octane
So if you're not advancing timing or adding boost... no hp gains? I thought so. Thank you
Old Aug 9, 2006 | 10:59 AM
TransAm396's Avatar
Re: High Octane
It will make it safer though.
Old Sep 22, 2006 | 03:46 PM
cjmatt's Avatar
Re: High Octane
the higher octane allows you to run more timing which equals more power. but if it isnt tuned for it, it wont really make a difference
Old Sep 23, 2006 | 08:48 AM
97WS6SCharged's Avatar
Re: High Octane
You also have to be careful with some of the higher octane stuff. Some race fuels are leaded which will screw up the O2 sensors.
Aug 24, 2015 06:41 AM
dkred94z
Aug 20, 2015 03:09 PM
FredM
Aug 14, 2015 01:49 PM
fundone2000-RZ
Pacific
Jul 21, 2015 07:21 AM
