Help with piston selection
Old Nov 23, 2009 | 03:19 PM
MysticBowtie's Avatar
I'm trying to order my rotating assembly, and I'm not sure what dished pistons to get. The brand isn't the problem, it's the amount of dish.
I want to be around 8.0 - 8.5 compression. I am assuming that my head bowls are stock and will adjust the head gasket accordingly after the motor is apart. I'm doing a 383 with up to 15psi on a D1SC. What do you guys think?
Old Nov 24, 2009 | 09:40 AM
roguedriver's Avatar
Assuming your using a stock head, i believe a -31cc is the most you can go, and even that will only take you to about 9.0:1 assuming its already had work on the chamber. If you want to go lower then that, then your probably looking at some aftermarket heads. If your not hip on that idea, then a worked head with that piston along with a FMIC and some meth injection and you should be fine, even at that boost level.
I run that combo using the JE pistons.
Ken R.
Old Nov 24, 2009 | 10:36 AM
That's what I was leaning towards (working the head). Thanks.
Old Nov 24, 2009 | 12:59 PM
MikeGyver's Avatar
you'll need 31cc dish to go that low with a stroker. aftermarket heads are usually about 4cc larger which helps lower CR. google compression ratio calculator
Old Nov 24, 2009 | 01:16 PM
I found a couple of calculators on google and their results were different for the same entries which is when I turned to you guys... But the consensus seems to be the -31cc throughout all the older posts I've found, then some head work. I've pretty much settled on the fact that I need to wait to buy anything until I get my heads off the car and do some measuring. Better safe than sorry...
Old Nov 25, 2009 | 06:14 PM
MikeGyver's Avatar
There's no reason to ask anyone, they're just going to ask for your information and enter it on the same calculator you should be using.
Old Nov 26, 2009 | 12:47 AM
wow....again, different calculators have different results and varied by as much as .5 . If you don't want to help then don't respond. I've gotten some PM's that told me that factory heads heads on a 383 won't get that low, even with machining. That is the kind of help I was looking for.
Old Nov 26, 2009 | 02:21 AM
MikeGyver's Avatar
I'm just saying the only way anybody can know is by doing the calculations. If you do it yourself you'll be less likely to make mistakes, which is exaclty what has happened, because yes you can get 8.5:1 on stock heads. Stock deck height is around .025 over plus around a .060 head gasket will get you there.
Some calcs might not ask you for head gasket bore and wont be (as) accurate.
http://www.csgnetwork.com/compcalc.html
Old Nov 26, 2009 | 08:24 AM
I see what you're saying. I appreciate it.
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
CARiD
Sep 7, 2015 08:21 AM
gonzo275rltw
Sep 5, 2015 06:26 PM
