help needed
Old Aug 10, 2005 | 07:37 AM
SloLt1Z's Avatar
help needed
Ok here's the issue i have a supercharged 95 z, the fuel pressure is falling off unfer boost. I put in a new regulator, and pump and still it's galling off to 40 lbs under boost. We are supposed to be leaving for the track tomorrow
Old Aug 10, 2005 | 09:19 AM
agrsiv95's Avatar
Re: help needed
Need more info on your setup....
What is the fuel pressure set at with the vacuum line off?
What kind of pump, regulator and pressure guage are you using?
Are you still using an FMU?
J
Old Aug 10, 2005 | 10:25 AM
SloLt1Z's Avatar
Re: help needed
The car no longer has a fmu, it has a intank walboro 340 pump, 60 lbs injectors, and a aeromotive fuel pressure regulator with the vacuum straight into the intake port
Old Aug 10, 2005 | 03:03 PM
OBE1 95Z28's Avatar
Re: help needed
Fuel filter in good shape?
Old Aug 10, 2005 | 04:30 PM
SloLt1Z's Avatar
Re: help needed
Brand new pump, filter, FPR, vaccum line from the fpr to the intake i can't figure it out
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
