help me with shopping list, building turbo LT1
Old Nov 13, 2003 | 05:23 PM
  #16
WS6 TA's Avatar
Originally posted by Camaro37
Forgive my ignorance but if you had a small turbo wouldn't you want a larger wastegate? A small turbo will allow less exhaust through compared to a larger turbo meaning alot of the exhaust would need to escape out the wastegate, therefore you would want a larger WG with a smaller turbo, right?
It’s all relative… bigger turbine making the same HP you don’t need as big a wastegate, but with generally, a smaller turbo just won’t move as much air, the engine wont make as much power and there will be less exhaust gas so you don’t need nearly as large a waste gate. This effect is probably greater then the turbine size changes, especially since you can have turbine sides that are the same physical size, flow the same but have a different AR….
LeftoverChinese
Jan 14, 2024 03:03 PM
Jrlt1
Jan 3, 2015 07:38 PM
Hurin
Dec 13, 2014 07:38 PM
siguy
Nov 27, 2014 10:07 AM
