help me with cam specs with turbo, race setup!
ok im thinkin bout changing my cam, right now its 570 610 236/244 on a 112, and done good so far, but now im upgrading some stuff and lookin to see if there is anything to gain by switching? im stayin hyd roller and still have a stock comp so 7k rpm will be about the limit!
I'm running something to the tune of 248 254 650lift on a 112 in a 370 motor with an 88mm. Depends on the setup. On the street it would be a bore. At the strip with a transbrake and a 2 step it works well.
You probably already have enough cam to make it to 7k assuming the heads and 76mm will get there.
I probably wouldn't go any bigger then unless you are aftermarket pcm. The above setup I have trashed ls7 lifters and made power to 8200.
I have a 475 75/83 going on my little lt1 and am curious to see how it acts. Stick shift street car though.
