Help with LT1 Pistion selection....
Help with LT1 Piston selection....
OK so im using Eagle ESP H-beam 5.7" Rods and A Scat Forged Crank. Im not looking to spend a million bucks but I am looking for something that will work well.
The project is a single T76 LT1 with a goal of around 550-600 on stock displacement. Im using Stock LE3 heads so I need to know what CR I should be looking for to get to my goal and still remain 91 octane friendly. thanks!
Not my auction but I happened to see it while looking for some other pistons
http://cgi.ebay.com/ebaymotors/JE-SB...spagenameZWDVW
I'm running wiseco's, a cheaper piston than JE or diamond, but should get the job done. With le3 heads and a good cam, you shouldn't have a problem making 550rwhp on 10lbs of boost on 91 pump gas.
oldschool
Feb 9, 2016 09:21 PM
