View Poll Results: Which head is better for a blower set-up
AFR LT1/LT4 195 street port NON competition
27.27%
AFR LT1/LT4 210 Race ready NON competition
72.73%
Voters: 11. You may not vote on this poll
Which head would work better with D1SC
I have some ported AFR's from LE, started out as 195's and they are 216 now. Flow a lot of air, but if I could do it again I would throw on a 235 runner RHS head (setup for reversed cooled) and my single plane would bolt right up.
Spin the blower hard, and have a good inlet, she'll make plenty of power
Not sure what issues you are talking about. I have had quite a few sets of heads thru him without issue (3 sets). Does jay think his heads cracked because of Lloyd's work?
Also seen a couple of sets of heads that were ported by him crack or have similar holes. Just too much of a "coincidence" for me to send heads to him.
That being said, I havent used AI in about year and a half, so i'm not saying go to them either. Just saying I have seen a couple issues w/ lloyds heads.
I have seen people have great results with no problems though.
I havent personally had a set done by lloyd, however, i did see a set of heads that had just been done by him, and after you kinda "poked" the intake chamber, a sudden pinky-sized hole appeared.
If it was in the port, then it isn't a big deal. Lots of guys end up getting that hole from aggressive porting on stock castings. If they are the same holes I am thinking of, then it is the bottom of the rocker stud holes that are breaking into the port. You just use loctite or thread sealant on the bottom of the stud and you are fine.
Maybe not, especially at a mass production level. However, lots of the very fast guys usually run heads that are hand ported, or they started CNC'd and the finish port work is done by hand.
stephen is a guy on a budget.
so you guys think the 195 street's will work for him?
