View Poll Results: Which head is better for a blower set-up
AFR LT1/LT4 195 street port NON competition
27.27%
AFR LT1/LT4 210 Race ready NON competition
72.73%
Voters: 11. You may not vote on this poll
Which head would work better with D1SC
Old Jan 24, 2010 | 11:13 AM
stephenpen's Avatar
I'm looking at the AFR 195 Eliminator street ports.
http://www.airflowresearch.com/index.php?cPath=27_28
and the AFR 210 race ready heads NON competition
http://www.airflowresearch.com/index.php?cPath=27_57
I'm thinking the 210s flow better so I might get better results with less boost. Less boost less detonation. But will they make for difficult tuning and bad street driving.
Old Jan 25, 2010 | 08:33 AM
RealQuick's Avatar
I'd go with the 210's if you are sticking with 383ci.
Old Jan 25, 2010 | 11:39 AM
reamo04's Avatar
why not go with the 227s?
Old Jan 25, 2010 | 03:22 PM
pineapplesink6's Avatar
I am of the opinion that the 227's will be harder to tune, and he doesnt need a port that big with boost.
Old Jan 25, 2010 | 03:58 PM
reamo04's Avatar
the better flowing head will allow him to achieve more power with less boost.
some of the fastest boosted LTx's are running the 227s.
If you have anybody that actually knows how to tune, the 227s arent hard at all.
Old Jan 25, 2010 | 04:08 PM
stephenpen's Avatar
You guys are killing me. I started this thread with two choices now I have three. I want to have a head that I'm not going to out grow in a couple years as I make my car faster. I have a chance to buy a good set of heads now so this might be the last set I buy. They dont just give them away.
Old Jan 25, 2010 | 04:36 PM
reamo04's Avatar
out of the two you posted, i would say the 195s just for the fact that i talked to eric bradby a while back, and he said the 210s are hard to get to flow good.
also you need to know, advancedinductions wont even touch AFR heads anymore, so its going to be harder to find somebody to do a GOOD, QUALITY port job on them. If I was spending the money, I would get some brodix cast with the LT1 coolant passages in them (yes, you can get this done)
Old Jan 25, 2010 | 04:37 PM
reamo04's Avatar
also, just a couple posts down is this link
http://www.gmhightechperformance.com...son/index.html
Old Jan 25, 2010 | 11:44 PM
cmroSS97's Avatar
Im gonna run the 227's....but i'll be running an f1a a big solid roller prob in the 240's/250's and some shaft mounts for the offset intake valves
Old Jan 26, 2010 | 05:51 AM
Nostang 96z's Avatar
I would go with the 210's for your application. With boost you want a nice big intake port to fill with a higher volume of air. You won't have to worry as much about port velocity as you have boost which acts a lot different than N/A engines. However, the D1sc will be limited with boost (you will have to pulley the hell out of it and possibly over spin the blower to make a good amount of boost) with the 210's as you would probably want to upgrade the head unit to an F1 or something along those lines. Is this a race set up or street setup?
Old Jan 26, 2010 | 07:33 AM
RealQuick's Avatar
Buy the AFR210 as cast and send them to Lloyd Elliott.
Old Jan 26, 2010 | 10:08 AM
97WS6Pilot's Avatar
The choice between 195's and 210's boils down to what rpm you want your motor to run best at. You would need a pretty large cam and higher rpm to make use of extra flow of the 210's. If it is a race only car then I would definitely go with the 210's because of the extra power at high rpm. If it is a daily driver then you would be happier with your power to be made a little lower in the rpm range.
Old Jan 26, 2010 | 11:22 AM
slomarao's Avatar
X2, race or street setup?
Old Jan 26, 2010 | 01:13 PM
why would he do that?
Old Jan 26, 2010 | 01:48 PM
RealQuick's Avatar
Because Lloyd can get some good numbers out of the 210's.
