Head gasket with blower...
Old Feb 7, 2004 | 12:15 AM
blk95zm6's Avatar
I need a recommendation please. 355 ci. 21cc dish pistons i need an .050 gasket to stay at 9:3:1.
Will the factory .051 headgasket live on 9psi, then 12 psi of boost? Does it have a decent fire ring? Readily available is the Fel pro .039, but that will put me at 9:5:1 compression.
I thought i could use a copper set, but i would have to o-ring the block or heads....Anyone have a bettor suggestion?
John
Old Feb 7, 2004 | 03:27 AM
rskrause's Avatar
Moderator
Other than the stocker I don't know of any gaskets that thick. I hear Cometic will make custom gaskets, but if so they are likely $$$. Lots of people run blowers on stock long blocks and the pistons go before the stock gaskets! But at 9 and then 12psi (and I assume heads, cam, etc.) you will be making a lot more cylinder pressure and I think there may be a problem with the stockers.
Copper gaskets are for race cars, as far as I am concerned. They always seem to seep coolant. If you had perfect deck and head preparation maybe they would be ok. FWIW, unless you have a zero deck a 0.051" gasket will not give effective "squish". I'd say you should consider the FP #1074 even though it will raise your CR a bit.
Rich Krause
Old Feb 7, 2004 | 04:12 AM
97WS6SCharged's Avatar
Will .2 more compression really make that much difference in the grand scheme of things?
Old Feb 7, 2004 | 05:01 AM
rskrause's Avatar
Moderator
No, I doubt it will be a major issue.
Rich
Old Feb 7, 2004 | 06:28 AM
Brady's Avatar
as stated, cometic will make whatever you want, and they will hold ALOT. but they're expensive- I think they are like $125 each for custom thickness gaskets.. I could be wrong.
I ran cometics @ 25+ pounds of boost, never blew one out.
I'll be running them again on my SBC.
good luck!
Old Feb 9, 2004 | 02:40 PM
blk95zm6's Avatar
Thanks for the help guy's...I was trying to keep compression as low as possible...(within budget too!) so it will have to live on the Fel-pro's at 9:5:1... With my 53cc (measured) LT1 chambers, .039 gasket and a 21cc dish forgings, .015 deck(assumed # from the last piston install) and .030 over i figured 9:5:1 compression....Sound right?
Old Feb 10, 2004 | 10:58 AM
sleeperz28's Avatar
Im running the felpro #1074's and 20lbs with no problems. Oh thats with head studs too, You will need those!
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
