Guys w/ 10+ psi, What Header gasket R U using?
Old Feb 10, 2004 | 10:38 AM
95 Silver TA's Avatar
Just as the topic says.
Thanks for any input.
Claude
Old Feb 10, 2004 | 10:43 AM
rskrause's Avatar
Moderator
Re: Guys w/ 10+ psi, What Header gasket R U using?
Claude
Fel Pro #1074 works fine. I and many others have used them. Last year I used them with 17psi and had no problems, though the mileage last season was limited. This year I am going to use Cometics, but they are expensive and clearly not needed for most combos.
Rich Krause
Old Feb 10, 2004 | 11:14 AM
IDOXLR8's Avatar
Re: Re: Guys w/ 10+ psi, What Header gasket R U using?
Rich Krause
I am using the same ones.
Old Feb 10, 2004 | 12:34 PM
MEAN LT1's Avatar
Felpro
Old Feb 10, 2004 | 12:43 PM
Cool, Thanks for the info guys.
I know that my current Grotyohann headers cant use the Felpro cuz the bolt whole are a litle different on the Grots. Did anyone have any problems with these gaskets and Hooker LT?
Thanks,
Claude
Old Feb 10, 2004 | 01:30 PM
Lisa33's Avatar
Isnt the Felpro 1074 a cylinder head gasket????
Old Feb 10, 2004 | 01:48 PM
JZ 97 SS 1500's Avatar
Yeah I think they jumped the gun there. They are FP 1406's for the headers.
Jose
Old Feb 10, 2004 | 02:03 PM
IDOXLR8's Avatar
Jose
Oops you guys are right. I though it said head gaskets.
Old Feb 10, 2004 | 10:51 PM
96 WS6's Avatar
Claude... I'm using percy's dead-soft aluminum with ARP 1" bolts. I have gone through much BS to arrive at this combo. The only other thing I'd suggest is those split lock bolts (Breslin and I believe I saw ARP ones in the new Jegs). The gaskets are excellent. The have worked where 1406's have failed. I am only running 6# but my cam has a fairly large exhaust duration and lift if that makes any difference. Regardless, they are awesome gaskets.
Old Feb 11, 2004 | 03:47 AM
rskrause's Avatar
Moderator
Oops, me too. I saw the reference to boost and got confused.
Rich
Old Feb 11, 2004 | 11:16 AM
Wild1's Avatar
Anybody try the copper exhaust gaskets from MR. Gasket?
Old Feb 11, 2004 | 08:12 PM
96 WS6's Avatar
I don't have personal experience but with the copper gaskets it has a raised section that it supposed to contact the header. Sometime the hole doesn't match up with the hole on the gasket and you will have an irreparable leak.
Go with percy's or that parker-hannifin one.
Old Feb 12, 2004 | 09:20 AM
Jesse_Boyer's Avatar
I'm o-ringed with copper gaskets. Not sure who's gaskets, but they are copper.
Once I get it fully tuned, I'll let you know if it holds.
Old Feb 12, 2004 | 02:36 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
even with 20+psi in the exhaust(turbo) i have had good luck with felpros, i tighten the HELL out of my header bolts tho
Old Feb 12, 2004 | 04:18 PM
Highlander's Avatar
I put them on but the car has seen only a few miles at most from the shop home to the shop for alignment and back home..
