Goin Turbo.. Got ?'s
Well I decided that I am going to change my setup on my new motor Im building. Its a 383ci with a Eagle 4340 Forged Crank, Eagle 5.7 H Beams, I will be taking the srp flat tops out and replacing them with some custom -39cc Dome pistons from Diamond and some total seal ap series rings. That will put me at 8:74.1 so that should be a good ratio to run at the amount of boost I am wanting to run. Im looking to run 20-25psi tops, and then lower boost when just cruising around. I will also be putting arp head studs in so no lifting heads happens. Now for the head gaskets.. I was told that running the Cometic will be the best. I just had my short block built from the machine shop and my block was zero decked so I don't know what the RA finish is. Can I bring it back up there and they can tell me? What about the heads, do they have to be 50RA or finer also? For the ECM. Can the ecm on a 93 car handle all the fuel adjustments and timing adjustments etc? Or do I have to run an aftermarket computer?
ElkyRacer
West South Central
Feb 9, 2003 08:51 PM
taner
Sep 9, 2002 11:36 PM
