Fuel for turbo..420lph in-line with 255lph?
Old Aug 7, 2006 | 11:53 AM
TransAm396's Avatar
Ok Im looking at different Ideas with this fuel system. Ive narrowed down my turbo kit...ptk kit with custom intercooler, t-76,and 60lbs injectors.meth injection. Now for the fuel.. I was told for the amount of power/boost a 255 might be or might not be enough. I plan on running 10psi street/14psi at the track(with 118octane) On LS1 speed they have a bosch 420LPH inline pump that says it supported 720rwhp without leaning..I dont plan on running close to that(600..650 max) Would a 255lph intake work if it were paired with that 420lph inline pump?-Mark
Old Aug 7, 2006 | 11:55 AM
Sparkz28ss's Avatar
Re: Fuel for turbo..420lph in-line with 255lph?
the 255 will be a restriction, I would just run the 420lph bosch pump and keep an eye on things...
Old Aug 7, 2006 | 11:59 AM
TransAm396's Avatar
...how?
Old Aug 7, 2006 | 12:14 PM
Sparkz28ss's Avatar
the bosch 420lph pump will be trying to push fuel through the 255, the 255 is not going to help move any more volume,
this works...not for long
Boosted V8--------------255lph------------190lph intank
this will work....but not so well
Boosted V8--------------255lph------------420lph Bosch (get out of the way Mr. 255)
this works well
Boosted V8--------------------------------420lph Bosh (aahh...better now that slow pump is out of the way)
best bet
Boosted V8--------------------------------Twin 255lph Walbro intanks
Old Aug 7, 2006 | 12:17 PM
TransAm396's Avatar
no..im saying physically..what would be inside the tank??
Old Aug 7, 2006 | 12:26 PM
Sparkz28ss's Avatar
well...from what I have seen the Bosch 420 pump looks to be external, so you would have to sump the stock tank...and I see that as a total waist of time,if I was going to run a sumpped tank I would just buy the Speed inc system...it looks great and is a nice setup...but alas...its a grip,1800 bucks or so to your door...and a month later
I would run two intank walbro 255lph pumps off a y-block...about 1/2 the cost of the bosch 420 and all the fittings and what not to sump your tank
http://www.geocities.com/marc94z/twins.html
Old Aug 7, 2006 | 01:44 PM
RealQuick's Avatar
Originally Posted by Sparkz28ss
Those are mine now
Old Aug 7, 2006 | 01:46 PM
TransAm396's Avatar
Originally Posted by RealQuick
Those are mine now
wanna make me one??..it looks like a PITA to make.
Old Aug 7, 2006 | 01:49 PM
RealQuick's Avatar
wanna make me one??
Sorry bro, I got too many things on my plate right now. The sticky at the top of the threads shows how to make one.
Old Aug 7, 2006 | 01:51 PM
TransAm396's Avatar
lol I was jk. So they work pretty good? Would they support my power goals? Also..I can use the stock lines and everything? Would you be able to give me part numbers on what I needed? (and where to get em)
Old Aug 7, 2006 | 02:23 PM
Sparkz28ss's Avatar
there was a thread with all the part numbers and where to get them...I look this morn for it when I posted the link to Marcs site...it should be around some place.
Old Aug 7, 2006 | 02:25 PM
TransAm396's Avatar
oh do you have the link?lol
Old Aug 7, 2006 | 02:35 PM
Sparkz28ss's Avatar
http://web.camaross.com/forums/showt...n+intank+pumps
Old Aug 7, 2006 | 03:55 PM
Roadie's Avatar
They're a lot easier to build than you think... Stock lines would be good to 600-650rwhp. Just make sure to cut off the section of hard line where it goes from 3/8" to 5/16" inside the tank. That's a major restriction. You'll want 3/8" all the way through.
If you do decide to go with aftermarket lines, add about $750 to your budget for lines, fittings, hose ends, etc, and fittings welded to your fuel rails (-8an unions work great for this).
As a side note, the biggest fear in a fuel system is loss of pressure at WOT. Since I'm running a Delteq with an MSD DIS-4, I used a nitrous fuel pressure safety switch connected to the kill line of the MSD box. I currently have it set just below the base fuel pressure... Granted, a lean condition and some detonation can occur with fuel pressure above the base fuel pressure at high boost. This doesn't take all the threats away, but it's one more step towards a perfect safety system.
Old Aug 11, 2006 | 02:43 PM
TransAm396's Avatar
so all that stuff inside the tank wont rust? like in the gas?(the clamps?)
