Finally Dyno #'s inside
Old Aug 19, 2006 | 03:44 PM
  #16
RealQuick's Avatar
Re: Finally Dyno #'s inside
Originally Posted by Schurters LT1
I didn't do so well on the emissions, i think i will get the car to pass...once this thing is set up perfect....
You'll have to fine tweak the part throttle A/F in the MAF tables most likely to get it to pass.
Old Aug 19, 2006 | 03:46 PM
  #17
Schurters LT1's Avatar
No MAF sensor Gen 7 now...and love it...
Old Aug 19, 2006 | 03:48 PM
  #18
RealQuick's Avatar
Nice!!
Old Aug 19, 2006 | 03:58 PM
  #19
CALL911's Avatar
Nice numbers! What kind of engine management system are you using? Also, was that done on pump gas?
Old Aug 19, 2006 | 05:11 PM
  #20
Pump Gas
Accel Gen 7 DFI
the Eng is 8:5.1 and with the large cam, compression ratio is low ..
My AFR was in the 10's for that 680 pull on the meth, witch was logged with the DFI, the dyno was one full point higher then the DFI si i went by the DFI
My timing was 22 total up top
I don't see why and nice 11.5 AFR and full timing (24-26) on pump gas when all is done....
Then i should see over 700rwhp....
Old Aug 19, 2006 | 06:26 PM
  #21
CJ's Avatar
CJ
Very nice #s. Ill have my car on the dyno in another month or so, hopefully my #s will be pretty similar.
Old Aug 20, 2006 | 09:00 AM
  #22
Cool good luck
Old Aug 20, 2006 | 10:16 AM
  #23
cjmatt's Avatar
Congrats on the numbers. your car looks almost like mine on the outside I just made 520rwhp thru one of Brets blower cams on a t-trim. I was only at 10 psi though. Stock top end though other than 1.5 roller rockers and springs. What kind of exhaust work do you have done? Id like to make about what you are next year when I can get a set of heads and a fuel system to match. it seems like my racetronix 255 is about maxed. also, what injectors are you running?
Bret, how similar is this cam to mine? mine seems like its making power to like 9k rpms. we shut her down at 6500 and it was still going
Old Aug 20, 2006 | 10:23 AM
  #24
Exhaust is 1 3/4 jet hot LT, 3" y pipe no cats borla cat back
Afr210 race ready heads
twin intake pumps
84lbs inj with Gen 7 controlling everything
Old Aug 20, 2006 | 10:36 AM
  #25
cjmatt's Avatar
twin intake pumps
yeah thats definitely way more raw than my setup. Thanks alot, you just cost me about a months salary
Old Aug 20, 2006 | 10:51 AM
  #26
95 Z/28 LT1's Avatar
Super Moderator
How many PSI?
Old Aug 20, 2006 | 11:02 AM
  #27
cjmatt's Avatar
Originally Posted by 95 Z/28 LT1
How many PSI?
I think he said 15 in the first post
Old Aug 20, 2006 | 11:04 AM
  #28
How many PSI?
15lbs it showed on the gauge i would have to look at my data logs to see for sure.....
Old Aug 22, 2006 | 09:25 AM
  #29
T/A lt1's Avatar
Nice numbers. What kind of tranny? If it's an auto what converter?
Old Aug 22, 2006 | 01:19 PM
  #30
thanks ..it is a M6 car...
