Finally... dyno numbers for the 'Bird!!!
Re: Finally... dyno numbers for the 'Bird!!!
Originally Posted by BADST95
Fuel system consists of a Racetronix twin in-tank pump set up with the 2nd pump turning on at 3600 rpms via a MSD rpm activated switch.
MSD 85 lbs fuel injectors
Custom fabricated adjustable fuel pressure regulator.
Custom intake and fuel rail set up.
Stock fuel lines.
This car is far from lean.
Stock fuel lines.
Just goes to show how far you can push the stock lines.
Guest
Posts: n/a
Yeah, I was planning on using the Racetronix in-tank dual pump kit but was going to upgrade the fuel lines. If his car isn't starving for fuel turning all the way to 6500, I don't think my 357 ci with an F1 and 15-18psi will starve.
Keep in mind that I am using a F.A.S.T. engine management system as the stock PCM wouldn't be able to handle this set up.
I have to look through my receipts to find out who the manufacturer of the copper head gaskets is. The rings are commonly used in nos applications... I gotta find that receipt. Crap... I'm drawing a blank.
Originally Posted by DiabloGT
how much did the whole buildup cost!? lol
Let's just say.. too much.
Originally Posted by SMOKNZ
Of course it would, why wouldn't it? You would need an impedance converter though.
Do you honestly think that the stock computer has same the tuning ability as a F.A.S.T? Not even close.
I'm sure this has been asked before but what kind of modifications did you need to do in order to make the F1 head unit fit properly? If I'm not mistaken ATI doesn't make a LT1 F1 kit.
Edit: Crazy numbers
Now get some times
Edit: Crazy numbers
Guest
Posts: n/a
Posted by: SantaCruz163
