Finally! 1 yr later. She's alive!
Old Jun 9, 2007 | 10:10 AM
ZBLKHELLRZR's Avatar
Thumbs up Finally! 1 yr later. She's alive!
I feel so stooopid too. My FP wasn't high enough. Makes me wonder if the dleteq would work now. The HI-6R I'm not sure about as I didn't retry it I just used the coil only. It was only at 35psi so I went to 60psi and bam it started then died. Set it to 43psi and boom 1st crank! I'm so far from putting it on the road though. 1 it's loading up on fuel at idle running 11.0 afr WAY too rich and causing the top end to just expose fumes to no end burning my eyes. Looking at the VE table it's idling around a 900rpm but the green bubble is lounging in the 315kpa area and value is 88. Man this is going to take long learning curve! LOL
Now I have to go study in depth on how to get the afr to come down at idle and a host of other things. I couldn't let it run more than a min because it was too intense. Have excellent oil pressure too 60 psi @ idle.
Just thought I'd finally share some good news. Now I'm off to do some research and get the afr to lean out at idle and go from there.
Silas,
Old Jun 9, 2007 | 10:52 AM
will62085's Avatar
what size injectors are you running?
fuel pressure at 35 should not cause it to not run, mine is fixed at all times at about 32psi (only way i can make my 160 lb injectors idle)
Old Jun 9, 2007 | 11:05 AM
I'm running 72lb RC injectors. I thought so too but the proof is in the pudding...well at least for me it is. I didn't do nothing different. Just verified I had spark and that was it. Only thing I did do was change the crank to run mode from 100 to 300 rpm. I've still have a weird problem w/ the XFI though reading a locked 24% tps reading. Don't know what that's about but I'll worry about that later.
Old Jun 9, 2007 | 11:08 AM
will62085's Avatar
Does the xfi use the TPS for accel enrichment? Without TPS, my car wont hardly run if its warmed up, no way will it cold start
Old Jun 9, 2007 | 11:17 AM
I'm not sure if it can be use for AE. I'd have to look and find out.
Old Jun 10, 2007 | 08:48 AM
CALL911's Avatar
I know you have some work in front of you to get the car where you want it, but congrats on getting her fired up!
Old Jun 10, 2007 | 10:18 AM
Boosted_Z28's Avatar
Yes! Congratulations...Glad to hear you got it running!
Old Jun 10, 2007 | 11:16 AM
Thanks guys! A lot of work is an understatement! All my tables are backwards for starters so I have to get that fixed before I can go any further. Have an oil leak at the accumsump soleniod valve. Took it apart and 60psi worth of oil blasted the garage. LOL Retaped w/ teflon and it still leaks at the npt fitting. Totally pissed off about that than I am about the XFI. Gotta run as I'm loading the update now and pray it works!
Old Jun 11, 2007 | 01:43 AM
Rodrigues's Avatar
Don't you think 160lb injectors are a bit overkill with your setup?
Old Jun 11, 2007 | 10:19 AM
will62085's Avatar
On the street yes, but once on race gas, and in race trim, 96's would be pushin it. The 160's were a bit cheaper than 96's so i opted for them.
They CAN be made to idle and have good street manners, just alot of work. My idle is 950rpm, ~15:1 AFR, with 1.2ms pulsewidths, 20* timing. I've found them to idle better without trying to use the IAC, just adjusted idle with timing and the idle stop screw on the TB.
Old Jun 12, 2007 | 01:45 PM
obzidian's Avatar
What kind of injector cycle are you running at WOT with the 160lbs?
as for the thread, sorry to hear that things are 100% Im with ya as before, i usually got hit with silly **** that just aggrivated me at best!
Old Jun 12, 2007 | 01:52 PM
Well the update didn't work. I can't get the ecu to recognize the laptop. So now I'm back to square 1. Hopefully I've got an older version tune I can play w/ that shows the tables being correct and go from there.
magman
Apr 15, 2016 03:08 AM
PopoFormula
Oct 12, 2015 04:19 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Ks0209
Oct 1, 2015 07:32 AM
kandied91z
Sep 30, 2015 11:43 PM
