FI engine cooling - post yours
Old Mar 5, 2008 | 09:16 AM
jsetzer's Avatar
FI Type:
Raditator:
Fans:
Coolant lines:
Coolant:
Stat:
Normal temp:
max boost temp:
I want to see what other people are doing to cool their cars. This is mine so far, but havn't driven on a day above @ 65 out.
FI Type: Turbo 10psi
Raditator: Stock - Vertical and moved towards front more
Fans: Stock
Coolant lines: Stock + modified with extensions
Coolant: Dexcool
Stat: 160
Normal temp: 175ish
max boost temp: 190ish
Old Mar 5, 2008 | 10:59 AM
Ponyhntr's Avatar
FI Type: ProCharger
Raditator: BeCool
Fans:BeCool twin (SPAL)
Coolant: Water with water wetter
Stat: 160*
Normal temp: 165*
max boost temp: 180*
Old Mar 5, 2008 | 11:59 AM
94SLUG's Avatar
Stock Rad, Lines, Fans, Ect...
160 Stat
Temp never never reaches 180...
I'll be going with a vertical rad soon, will use a single low pro fan, and griffin rad. Room is nice, no abs and vert rad. I never use my AC so it's going also...
Old Mar 5, 2008 | 12:57 PM
Lisa33's Avatar
F1 procharger
Stock radiator, lines and fans
Water + redline waterwetter
160 Tstat
Normal temp: 170-180 after a burnout and a 1/4 run its usually around 10-15 extra (accourding to datamaster)
Old Mar 5, 2008 | 01:03 PM
Sparkz28ss's Avatar
FI Type: Procharger
Raditator: Griffin two row big tube
Fans: Flex-a-lite 210
Coolant lines: Goodyear High miler
Coolant: distilled water w/ DEI Radiator Relief
Stat: 160 drilled
Normal temp: 165-180 winter / summer
max boost temp: 170- high 180s w/s
Old Mar 6, 2008 | 08:40 AM
mzgp5x's Avatar
FI Type: Procharge D1
Raditator: Be-cool. Moved forward.
Fans: 2- Flex-a-lite low profile (custom mount)
Coolant lines: stock with ext.
Coolant: Dex-cool
Stat: 160F with fans on @ high speed LT1_edit.
Normal temp: 170 to 185 summer.
max boost temp: meth-h20 and 25x8x3" Spearco IC.
(97ss 383 - D1 - M6)
Old Mar 6, 2008 | 08:45 AM
The SRZ's Avatar
FI Type: F1 ProCharger
Raditator: Fluidyne
Fans: Stock
Coolant lines: Goodyear High Miller
Coolant: Prestone/ Water Wetter
Stat: 160
Normal temp: 165ish
max boost temp: 180ish
Old Mar 6, 2008 | 01:04 PM
ramair96ws6's Avatar
FI Type: D1SC
Raditator:stock
Fans:stock
Coolant lines:stock
Coolant: Dexcool
Stat:160
Normal temp:180
max boost temp:210-220(summer time in vegas ac on)
Old Mar 9, 2008 | 01:02 PM
CALL911's Avatar
FI Type: ATI D1SC
Raditator: stock
Fans: stock
Coolant: Standard Prestone/water mix
Stat: 160
Normal temp: 180
max boost temp: 190 on a hot day
oldschool
Feb 9, 2016 09:21 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
