Fastbird93's Single Turbo Build Thread
Old Jan 13, 2009 | 09:44 AM
Fastbird93's Avatar
This has been a long time coming. Figure it's time to start putting a build thread together though it's going it's still going to be a while to completion. I haven't been around here in a while but this site has been instrumental to me as an f-body enthusiast for a very long time. Anyway, it's all going into this:
First up, the motor:
4.030 bore 93 LT1 Block
Lunati Sledgehammer 3.75" Stroke Crankshaft
Lunati Pro-Billet 5.7" Rods
Diamond Custom Dished Pistons
Diamond Pro-Select rings
Trick Flow 195CC LT4 Heads and LT4 Intake Manifold ported by Lloyd Elliott
BRE Custom Camshaft
Comp 1.6 ratio 7/16" stud Pro Magnum Rockers
Manley 7.215" one piece pushrods
GMPP Guide Plates
Meziere Electric Water Pump
Hypertech 160* T-Stat
BBK 58mm TB
Fast XFI........I think that's about the jist of the main stuff.
Drivetrain:
McLeod Street Twin Clutch
Modded Factory Master Cylinder to be adjustable
Factory Hurst shifter w/UMI Short Stick
Driveshaft TBD still......
Strange 12 bolt, loaded up.
Turbo Kit -- LT1 Boost Hot Part Kit, in progress, Jon, post up the pics please
PT76GTS Turbo
JGS 50mm Waste Gate
JGS 56mm BOV
Ebay CXRacing 4" core FMIC -- will be a horizontal mount under the nose
Fuel System
Home Built double pumper
-8 in and -6 out rails modded by me, powdercoated black
Will be building this in the coming couple of months.
I'll keep this thread updated with pics as I find time to do the work. Currently the car has the motor/trans out, and has been on the same jackstands since August of 2007 now waiting on turbo parts due to one reason or another. Really the only things I need other than the hot parts at this point are fuel injectors, methanol kit, make my cold side piping, to build my fuel system, reseal the rear axle, get a driveshaft, and get everything installed.
More to come. Tonight I'll try to get pics up of all the parts I have sitting around. About $6K+ scattered throughout the house (pantry, dining room, living room, kitchen, garage..... I love my wife).........
Old Jan 13, 2009 | 10:10 AM
axehead's Avatar
good luck man
Old Jan 13, 2009 | 10:13 AM
RealQuick's Avatar
Old Jan 13, 2009 | 08:13 PM
Fuzion1's Avatar
Nice setup. How much HP you going for?
Old Jan 13, 2009 | 08:29 PM
Fastbird93's Avatar
Hopefully around 800 at the ground on lots of boost, pump gas, and water/meth injection.
Old Jan 13, 2009 | 08:42 PM
jay_rich's Avatar
Woow clean looking...im interested to see how the hotside is gonna be.
Jay
Old Jan 13, 2009 | 09:06 PM
RealQuick's Avatar
Crossover pipe:
ground clearance:
Old Jan 13, 2009 | 09:10 PM
jrutland's Avatar
Awesome! I am getting ready to start putting mine together in about 3 weeks. My motor is almost identical to yours so it will be neat to see how similar the numbers will be. I have the header kit from Realquick also with a TC76. Goodluck on yours!
Jerry
Old Jan 13, 2009 | 09:16 PM
Fastbird93's Avatar
Parts ****!!!!!
CSRacing Intercooler, Griffin Radiator, Jegs powdercoated radiator hoses. Probably not going to use the radiator/hoses due to not needing to stand up the radiator with Jon's kit.
Black powdercoated goodies!
Fast XFI! This thing is pimp to say the least.
Fast XFI Injector Harness
Fast Track Performance XFI Integration harness for the LT1
PT76GTS and Blanket
PT76GTS ID Sticker
Old Jan 13, 2009 | 09:17 PM
Fastbird93's Avatar
McLeod Street Twin fresh off a rebuild
JGS 56mm BOV and 50mm Wastegate
Energy Suspension Motor Mount
Fast 3Bar MAP Sensor
UMI Performance Lower A-Arms
Used (but good, and cheap) BMR K-Member
Old Jan 13, 2009 | 10:08 PM
jay_rich's Avatar
wow nicw amount of parts!
Jay
Old Jan 13, 2009 | 10:31 PM
Fastbird93's Avatar
Jay
Yup! Just need to get them ON the car.
Old Jan 16, 2009 | 08:43 PM
slomarao's Avatar
nice, very nice.
Old Jan 16, 2009 | 09:23 PM
reamo04's Avatar
very nice, cant wait to see how it comes together
Old Jan 16, 2009 | 09:24 PM
reamo04's Avatar
Originally Posted by RealQuick
Crossover pipe:
ground clearance:
so that goes IN FRONT of the oil pan? never thought of doing one like that. You just opened up a **** ton of ideas for me on my new build
