FAST or FACTORY serious
Im building a high hp @700 hp plus supercharged 95Z and my wallet isnt deep but if Fast is best then ill do it. The biggest thing I see I need a Fast sysytem for is injectors. I am aware that there is a product that allows you to use the low injectors with the factory computer. I want to sreet drive the car and if I use fast I have to intergrate it with the speedo, abs, ignition this is expensive. I cant help but think that using a properly programmed factory computer that still uses MAF and knock sensors etc. that it makes sense maybe im wrong any help?
There are a few people making 700 hp while still using their factory computer. The box you are referring to is the Acceloronics Impedance Converter box. You may want to try and post this on the Forced Induction Board.
Factory computer and Acceleronic impedance converter, 700rwhp through a TH400! The Acceleronics box is great. If I were to do an aftermaket ECU I'd consider the Electromotive though. I like it better than the FAST.
Rich Krause
Rich Krause
F'n1996Z28SS
Aug 23, 2023 11:19 PM
