F-1A MAX Boost??
Old Feb 11, 2010 | 08:30 PM
cmroSS97's Avatar
F-1A MAX Boost??
What do you guys think is the most boost i will be able to get out of an F-1A Blower??
396ci around 9.2:1 compression
AFR 227 fully comp ported heads
Big solid roller prob spin to 7200-7400rpm
Single plane manifold
FMIC with 3, 3.5, or 4'' piping
Old Feb 11, 2010 | 08:47 PM
Diplomat's Avatar
Cool
I'm runing 18psi the system is capable of running 35psi but thats the max, I would think 30 to be safe and manageable. What are you trying to do?
Old Feb 11, 2010 | 09:01 PM
cmroSS97's Avatar
Trying to make 750 rwhp on pump gas.....shooting for 800 but would be happy with 750 then add a meth kit
Old Feb 12, 2010 | 02:23 PM
Diplomat's Avatar
What engine? I built a 383 LT1, 18psi F1 ProCharger and the engine made 1043hp. I'm having problems with transmission now, I can't find anything to hold it. Once I do, I will bump up the boost to take out the power loss though drive train. My goal is 1000-1025 to rear wheels. Pump gas and no meth inj.!
Old Feb 12, 2010 | 02:26 PM
cmroSS97's Avatar
Wow!!! Ya thats my ultimate goal about 850rwhp=~1000 flywheel hp
My Basics=
396ci LT1 around 9.2:1 compression
What are your rough cam specs??
Old Feb 12, 2010 | 06:08 PM
rskrause's Avatar
Moderator
On my 383 with fair but not fantastic heads the max boost out of the F1 is 26psi.
Rich
Old Feb 12, 2010 | 06:47 PM
cmroSS97's Avatar
Rich
26#s huh NIIIIICE!!!....are you running ARP studs and fel-pro gaskets. J/W cause thats what I was planning but I'm hoping I dont have problems with the studs leaking coolant.
Old Feb 13, 2010 | 05:29 PM
Diplomat's Avatar
26# is nice, how much hp are you putting down to the ground? As far as coolent leaking when torquing the bolts go up in increments not to spec lbs, this will help spread the weight/pressure over the gasket.
Thats how I've been doing it and never had any leak other than water pump blowing and thermostat giving out. If your not runing the car in winter and your not leaving it outside try a leaner mix of coolent. Coolent does eat those gaskets too if the engine does not run for a while.
RUENUF
Mar 13, 2016 03:37 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
96SilverRam
Sep 7, 2015 10:51 PM
Henson071
Aug 4, 2015 09:32 AM
