Exhaust gaskets (Jordon???)
Old Apr 27, 2003 | 11:31 AM
  #16
arnie's Avatar
To expand on what Mark stated, the gaskets used, although the quality of which has a marked effect on seal, is secondary to the exhaust manifolding/header one uses. One needs to determine whether the thickness of the flange is adequate. I believe the weak link in a gasket dependability/durability issue is the stability of the manifold/header under the abuse of the higher heat environment of a turbo system.
Old Apr 28, 2003 | 09:17 PM
  #17
JordonMusser's Avatar
West South Central Moderator / Special Guest
damn, those norlocs look cool. Anybody used them with luck? I saftey wired mine, but man is it a bitch when I have pull 'em.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
FredM
Mar 6, 2015 03:04 PM
Jazsun
Dec 29, 2014 12:14 PM
