electric driven superchargers????
Old 07-22-2004, 11:04 AM
ss#1230's Avatar
anyone seen these.....theres a couple different guys selling them on ebay....
see here
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
ss#1230 is offline
Old 07-22-2004, 11:08 AM
ss#1230's Avatar
Re: electric driven superchargers????
or this one.....
ss#1230 is offline
Old 07-22-2004, 02:50 PM
Ultra_Dog's Avatar
Red face Re: electric driven superchargers????
Those look like garbage. I doubt they even offset the vacuum your engine creates, let alone create any positive boost pressure inside your engine. Do the math. If you engine is drawing 175 cubic inches of air into its cylinders per revolution and you are turning at 5,000 Revolutions per minute, that would be, in a perfect world, 875,000 cubic inches of air per minute. Even if you divide that by 1,728 (12 x 12 x 12), you still have a draw of over 500 CFM.
Seems that if these are capable of 250 CFM, then you might get your manifold to record some pressure if your RPM was less than 2,500 and everything else was perfect.
I think you'd be better to use these to cool your face on a hot day.
Ultra_Dog is offline
Old 07-22-2004, 03:02 PM
Camaro94Lover's Avatar
I looked over those eletric ones before and another problem I see is that the flow would be constant, unlike a mechanical supercharger. The RPM of the engine would drive the belt to the charger and increase or decrease the flow as neceassry (boost/vac). Even if the CFM was close, there would have to be a way to tie into the vehicles tach which would adjust the electric blower as necessary. If it couldn't do that, the steady flow of air at idle would give the computer all kinds of wacked out readings.
Camaro94Lover is offline
Old 07-22-2004, 03:52 PM
LukeZ28's Avatar
Here is more of a working design.
Electric Supercharger
LukeZ28 is offline
Old 07-22-2004, 05:20 PM
Fuzion1's Avatar
Ya Bro, I put one of those ****'s on my Honda Civic yo. Car be pushing 500 hp now.
Fuzion1 is offline
Old 07-22-2004, 07:19 PM
ss#1230's Avatar
it says that its controlled by a button the driver uses to turn it on and off. so just imaging how much air that thing is blocking when not in use!
so basically its only used at WOT.
and my first thought is what ultra dog said....it probably wont even keep up with the vacuum the engine creates.
ss#1230 is offline
Old 07-22-2004, 08:39 PM
97WS6SCharged's Avatar
Yeah, but on a 1.6L, it's probably capable of producing some sory of positive manifold pressure.
97WS6SCharged is offline
Old 07-22-2004, 09:00 PM
JZ 97 SS 1500's Avatar
Cheaper and easier to just throw a leaf blower on....lol
Jose
JZ 97 SS 1500 is offline
Old 07-23-2004, 07:07 PM
LameRandomName's Avatar
Instead of sending that guy $140, send me $20 and I'll light a candle and pray to the Horsepower Gods for you, which should be equally effective.
LameRandomName is offline
Old 07-23-2004, 08:38 PM
Jose
Gas or electric?
Old 07-23-2004, 11:57 PM
BLUE95ZZ's Avatar
This idea is so stupid it shouldn't even be discused again on this forum. Just my opinion
Matt
BLUE95ZZ is offline
Old 07-24-2004, 12:03 AM
It's been discussed many times before and will be again. Count on it.
Old 07-25-2004, 07:28 AM
irishz28's Avatar
beleve it or not ive seen someone using a leafblower at the track, dude just poped his hood in the pits and pull started it. i dont know if it idi anythin for him but he was hitting 12s.
irishz28 is offline
lt1xondeck
03-18-2016 07:22 PM
Henson071
09-18-2015 04:01 PM
08-07-2015 01:26 PM
Highlanderrtl
07-24-2015 03:34 AM
Quick Reply: electric driven superchargers????
