Dyno owned
Jake i am so glad to see you work the bugs out of the car after the last few years of problems after problems. Seriously guy's this is one awesome car you would not have any clue the car is making that kind of power if he pulled up next to you, It is very quiet and sleeper looking. Jake drives the car all the time when it's nice out so i would consider it one hell of a daily driver 6speed and all, And you should see it go. Seriously Jake you need to leave that setup alone and concentrate on getting that thing to hook up! And you will dominate the streets around here.
Way to go Jake!!!!!!!!
Sean.
Sean.
Re: Dyno owned
Originally posted by sleeperz28
I went out to the dyno today and was very impressed with the numbers the car laid down. My 72# injecters maxed out, 100%, at 19 psi. Until I get bigger injectors max horsepower is still a mystery. However, what i made is plenty for a street car
Results of the day:
938rwhp@5950rpm
924rwtq@4975rpm
Results of the day:938rwhp@5950rpm
924rwtq@4975rpm
IMPRESSIVE
Was that on pump gas?Damn u are making more power than my friends viper with a low C/R 550CID stroker and a JT Trim SC running 15psi.
Still have not got the graph up. My scaner software is not working with my new opp system. I will have to bring it down to school and scan it in there. I will see if I can get it in tomorrow. I have to make a correction on the actual torque numbers. When I was admiring the graph the other day I took a closer look. It appears the peak torque numbers are higher then peak horsepower. When the guy tried to select peak torque he must have not selected the top of the graph. In other words it appears the torque is in the upper 940's.
Anyone that has had trouble accessing the website, I have tried it with no problems. If you have a slow internet connection it will take a while to load.
As for the power on pump gas its not worth trying to nickel and dime the costs of gas. When adding up my time and the cost of parts id say Race gas is much cheaper
by that monster.
