Dyno Numbers!
Dyno Numbers!
Dynoed the car today at 15 PSI.
586 hp 607 Tq
Im pretty happy with it.
Have a really weird fuel issue around 4500 rpm that was there on every pull. Goes lean then rich, then back to where it should be by 5000 rpm. Couldnt get it tuned out no matter what. I think thats hurting the power and might be able to break 600 at the wheels with some more time on the dyno. Had to cut the time short because it was getting late.
586 hp 607 Tq
Im running the LE1 heads with the larger valves, so nothing crazy.
It was late and didnt have a lot of time on the dyno, didnt get to play with the timing at all. Car also seemed to max out about 5500 rpm which I thought was low. My cam should be good to about 6200. Im wondering if the turbo is a little undersized.
Oops, I read t76... you have a 67. Possible My MP t70 is falling off up top, but I think the t70 is actually closer to a 60-1 or something. I think the wheel is in the ballpark of 63mm.
But that still doesn't seem bad. I made 640# but lost something like 200# between 5 and 6k. My peak HP was really low.
racecarz28
Mar 30, 2015 09:55 PM
Joe Brodman
Jul 24, 2002 05:24 AM
