to the dyno, james
Old Dec 1, 2003 | 06:31 PM
  #16
Shawn 97 Z28 M6's Avatar
Texas Moderator (1998-2009)
Hey Jordon, I checked the graph again... It's all broken up above 5700.. Startes to break up a little earlier than that even actually.. next time we'll put on both cables, double the pleasure ~ double the fun!
Old Dec 1, 2003 | 06:46 PM
  #17
INTMD8's Avatar
From: I reached back like a pimp and smacked that LS1....
Congrats on the numbers Can't wait to see what it will do with some more boost.
What size is your downpipe/exhaust ?
How is the idle and driveability with that 230 cam?
Old Dec 1, 2003 | 08:00 PM
  #18
JordonMusser's Avatar
West South Central Moderator / Special Guest
yea, my website totally sux.
lol.
3.5" DP, 4" oval exhaust under the car, 4" round out the back through a magnaflow straight through muffler
cam drives fine. The "worst" driving motor I ever had was a cc306/stock bottom end/ported heads.. but even it wasn't too bad... and this is MUCH better(much less overlap, more cubes)
Old Dec 1, 2003 | 08:07 PM
  #19
Grover's Avatar
How many cubes do you have in your motor?
If I was to rebuild a bottom end for a turbo setup, what cubic inch size would you recommend?
Old Dec 2, 2003 | 11:15 AM
  #20
SSpray's Avatar
have you auto X'ed with that set up?
How is it? or how do you guess it will be?
Old Dec 2, 2003 | 11:41 AM
  #21
more cubes the better.. if money isn't an object.. maybe a 434?
I did attempt to autoX the car, wayyyy too much power. However once i dialin the boost controller, i think it will be ok.
its certainly not built as an autoxer, NA would be the way to go for that... but I have/will autoX it cause its fun
Old Dec 2, 2003 | 03:18 PM
  #22
PNYKILR's Avatar
From: Albuquerque,NM--5,600 feet above you sea-level cats
Now all we need it some video of you smacking around some of those high hp Supra's in your area. This is Neal, from Albuquerque,NM(Nicks friend).
Old Dec 2, 2003 | 04:07 PM
  #23
absolutely!
After I get all the little stuff worked out over my xmas break, i ill be takin her racing
Old Dec 2, 2003 | 04:38 PM
  #24
brain's Avatar
I say run it on radials! Bust off a 12.5 @ 140! Supra territory or what! LOL
Old Dec 2, 2003 | 05:27 PM
  #25
neil350's Avatar
Awesome numbers man, do you plan on developing this set up in to a kit?
Old Dec 2, 2003 | 10:14 PM
  #26
SSpray's Avatar
Originally posted by JordonMusser
absolutely!
On the highspeed track in Dallas (GB)?
I might be back in the area to see it run.
Old Dec 2, 2003 | 10:34 PM
  #27
the spindoctor's Avatar
sounds like you'll be on the prowl for a certain red mustang in dallas pretty soon.
Old Dec 2, 2003 | 10:56 PM
  #28
neil-
I dont feel like somebody can truly buid a "kit" that has no compromises.. In order to get the tight tolerances required to fit a large turbo, keep AC, ABS, cruise, and keep the car easy to work on i reallly prefer to build the kit directly on the car.
Old Dec 2, 2003 | 11:20 PM
  #29
neil350's Avatar
Cool man, I talked to G and he said the car was running great and he sounded impressed with it. So you know if it gets the G seal of aproval you built some thing failry wicked.
Old Dec 3, 2003 | 11:57 AM
  #30
95_RipperZ's Avatar
I'm moving to Texas, you people are crazy down there. I like it.
