dual spal 11" fans?
Old 10-23-2003, 12:29 PM
  #16
Highlander's Avatar
You may have no problems depending on your climate... Its good idea to have nice opinions... When you bought the car you didn't have any problems either or you shouldn't...
Either way I would like to know if there is really more airflow and if it will help on really really hot days or a bigger radiator is the only solution... Most people have had no difference with the bigger radiator.. some people have had worse and others better... Looks to be the same with fans... I certainly dont think that a substantially bigger radiator will not yield any gains and so are the fans.. So it would be nice to see some detailed experiences...
I guess that for 600rwhp am going to go with the be-cool and the spal fans as LJ did
Highlander is offline
Old 10-23-2003, 12:44 PM
  #17
mongse_1's Avatar
Semi-related here, but has anyone run one of AFCO's radiators for the LT1 cars? I think they were in the high 400s which was lower than BeCool.
Brady, how much room did you gain w/ the 16" fan? I need to get as much room as possible and switching fans looks like an easy fix.
mongse_1 is offline
Old 10-27-2003, 08:52 AM
  #18
95 Silver TA's Avatar
Someone here must have the info on what CFM the stock fan flow or what kind of benefits they saw by switching to the aftermarket fans.
TTT
Thx,
Claude
95 Silver TA is offline
Old 03-31-2004, 09:08 PM
  #19
Highlander's Avatar
TTT...
any more info guys??? what is the bestand easies fan setup?
Old 04-01-2004, 08:19 AM
  #20
mongse_1's Avatar
I'll be running the dual 11" Trimline's like suggested above. This will be on a custom radiator as well (stands straight up instead of @ a rake), and I need all the room I can get on my setup.
mongse_1 is offline
Old 04-01-2004, 08:36 AM
  #21
Highlander's Avatar
Let us know how it goes... I want to do something when I get my car back together and i think i will still be using the stock radiator... i just want the fans to flow more air for when the a/c comes on.
Old 04-01-2004, 08:39 AM
  #22
mongse_1's Avatar
I'll be posting quite a few pics in the next few weeks of various things.
mongse_1 is offline
Old 04-01-2004, 08:43 AM
  #23
Maldo's Avatar
Does someone have pictures of their aftermarket fan set ups
Or what the flex-a-lite trimline dual fan setup looks like ..
Jim
Maldo is offline
Old 04-01-2004, 09:01 AM
  #24
mongse_1's Avatar
http://www.flex-a-lite.com/auto/html/trimline-fan.html
Trimline straight and S-style blades
mongse_1 is offline
Old 04-01-2004, 09:16 AM
  #25
Highlander's Avatar
There is no dual setup that could fit the lt1 and the setup that is there only flows 1800 cfm
Old 04-01-2004, 09:23 AM
  #26
Highlander's Avatar
I would like to see a setup of the pusher fans and how to wire them.
Old 05-18-2004, 11:41 PM
  #27
TonyJ's Avatar
The flex-a-lite 220 does fit (actually really nicely...) I'll post pics in a day or so. They are supposed to flow 2500 cfm. Wait til you see the pics. This is going to be a very popular swap, if they flow as much as the stock fans...
They definately open enough room for the HD Meziere, so there's 50% more water flow than the CSI, as well...
More later, TJ
TonyJ is offline
Old 05-18-2004, 11:55 PM
  #28
Highlander's Avatar
Stock fans flow around 1800...
the meziere flows more water than the CSI?
Old 05-19-2004, 08:41 AM
  #29
TonyJ's Avatar
The CSI is rated at 35-37 gpm depending on where you read. The standard Meziere is rated at 43 and the HD Meziere is rated at 50. The HD should flow ~70% more water than the CSI.
TonyJ is offline
Old 05-19-2004, 05:26 PM
  #30
TonyJ's Avatar
http://www.webpeak.com/~tony/bluez/fan1.jpg
http://www.webpeak.com/~tony/bluez/fan2.jpg
http://www.webpeak.com/~tony/bluez/fan3.jpg
__________________
TonyJ is offline
Quick Reply: dual spal 11" fans?
