Dual Intercooled Procharged 8psi Reliability?
Old Sep 2, 2006 | 03:49 PM
93Phoenix's Avatar
I'm looking at a Dual IC Procharger with 8lb pulleys, comes with a FMU and the computer tune to match.
Will this motor last? Car will not be a daily driver but how long will the bottom end/pistons last? I see people getting away with 6-7 psi non-intercooled so is an intercooled 8psi procharger safe for my stock internal LT1?
Thanks,
Andy
Old Sep 2, 2006 | 05:21 PM
rskrause's Avatar
Moderator
Re: Dual Intercooled Procharged 8psi Reliability?
YMMV. Hard to say how long it will last, but don't expect OEM levels of reliability.
Rich
Old Sep 2, 2006 | 07:39 PM
bowtiepwr's Avatar
>I did this... I bought a spare LT1 block and had it bored and clearanced (for my 396) then when I could I had it rebuilt and installed when the stock engine let go.
Old Sep 3, 2006 | 08:52 AM
CALL911's Avatar
Anything more than about 6#'s of boost on an LT1 and I would be looking to get more than just the small twin intercoolers that ATI gives you. This goes for stock OR a forged built bottom end.
I have seen where they can't keep up with 8#'s before. If anything I would just say go with a FMIC.
Either way you go, even intercooled you won't be able to safely run very much boost on a stock bottom end motor. This IMO defeats the whole purpose and isn't very cost effective seeing as how you will probably drop at least a few thousand in the blower alone, not to mention injectors and other misc. parts. And 5-7#'s of boost really won't gain you too much in the pig HP picture of things. It would be more cost effective power/money to go another route. Or if you are set on the blower idea then save up some more $ and get that bottom end built for it.
Old Sep 8, 2006 | 06:32 PM
slimdawson's Avatar
No one here can tell you how long your stuff will last. I've seen where some guys dont make it home from the dyno almost. I have been fortunate and mine has lasted over 2 years at over 8#. Plus, mine had about half the miles yours did(if its the car in the sig).
Who knows. You'll find out I guess.
Old Sep 16, 2006 | 12:11 AM
blackztpi's Avatar
not to steal the thread, but i was kind of wondering the same thing. I built my motor all forged, but for higher compression N/A. I'm not really that happy with the power levels and kind of want to go with a used supercharger kit or something if a deal pops up. my ring gaps are stockish and piston to wall is .004" sop i realize i can't go crazy, but i was thinking that i could at least run 8-10 psi on that setup, assuming i put on some larger 70cc afr headsto get compression down in the lower 9's. would my setup be safe?
Old Sep 16, 2006 | 04:42 PM
OBE1 95Z28's Avatar
I must be missing something, how did you end up with 11:1 CR with -12cc pistons and stock heads?
Old Sep 16, 2006 | 07:15 PM
lethal93ta's Avatar
I put my blower on at 68000 miles it lasted 2 years with about 5000 miles on it, that was hard miles but every set up is diffrent and you have a lot more miles on yours. I was running 9 lbs of boost on mine single dual core intercooler, I went from a 13.7@102 MPH to a best of 12.26@ 115 MPH, my average time was around 12.4m if I would have got my gears and converter on the car before it blew I know I could have hit 11s.
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
football4life
Oct 4, 2015 07:48 AM
RX Speed Works
Oct 1, 2015 10:19 PM
95blkss
Sep 22, 2015 03:18 PM
