Do you need a Bypass Valve is you have a BOV??
I'm going to be running a vortech strim and was wondering if I should get a bypass valve or a blow off valve. I heard that blow off valves release more air.
Re: Do you need a Bypass Valve is you have a BOV??
I think what your asking is"Do you need a bypass valve if you have a bov.?"
The answer is no b/c there essentially the same thing. But alot of people with blowere applications are running a bov with success.
If your running alot of boost a bypass valve would be almost necessary. A blow off valve releases air when there is a sudden pressure increase (letting off the gas under boost). A supercharger is ALWAYS making pressure before the TB blades. If there isnt something to release the pressure you can kiss the bearings on your SC good bye. A bypass valve is open when your engine is under vacume (idle and cruising) a blow off valve is closed.
From: I reached back like a pimp and smacked that LS1....
Bypass valve- Supercharger application. Open under vacuum/cruising to 'bypass' air from the supercharger. Closed under boost.
BOV- Turbo application. Closed under vacuum/cruising. Only opens after boost is made and throttle closes.
My S-Trim kit came with a by-pass valve....no need for a BOV.
Here's the Mondo if you don't have it.
http://www.vortechsuperchargers.com/...s/aircomp.html
14
Aug 11, 2015 12:03 PM
RX Speed Works
Jul 24, 2015 02:25 PM
