D1-sc Boost Help
Old Jun 22, 2004 | 12:59 PM
1984camaroz28's Avatar
D1-sc Boost Help
i found one for sale but hey has it running at 12psi... My motor is 9.9 almost 10 to 1 Will i get away with runing 12psi on pump gas or will i need a different pulley to make less boost
Old Jun 22, 2004 | 01:11 PM
MEAN LT1's Avatar
Re: D1-sc Boost Help
Thast still alot of compression to be running that much boost. I would pulley find another pulley combo and come down on the boost. What else have you done to the motor b/c if she has the stock bottom end then be prepared for a rebuild.
Old Jun 22, 2004 | 09:02 PM
its a stroker motor with a big cam... i no u can run 11psi np
Old Jun 23, 2004 | 06:16 AM
IDOXLR8's Avatar
If you can run 11lbs without a problem then I do not see 12lbs being a problem. Also when you start messing with higher compression and boost you typically have to either turn down the timing or run race gas.
Old Jun 23, 2004 | 11:10 AM
RealQuick's Avatar
Forged components????
Old Jun 23, 2004 | 11:26 AM
of course
Old Jun 23, 2004 | 12:03 PM
IDOXLR8's Avatar
OK I just noticed that you said that he says the D1SC set for 12lbs of boost. What kind of setup is he running? You will not see 12lbs unless your setups are identical.
Old Jun 23, 2004 | 12:24 PM
i not shure i also found a S-trim .... Are they any good?
Old Jun 23, 2004 | 12:38 PM
RealQuick's Avatar
I have an S Trim i am going to be using because I already own it. I was gonna install on my my stock bottom, but decided to do a 383 buildup. It is a small blower for the cubes, but it will do for now.
Now if the person you were gonna by the D1 from was running 12psi on a 350, then you wont see that much on a 383. Also how well the heads flow can affect the boost levels as well. Big cc heads should show less boost then smaller cc heads (runners). Correct me if I am wrong.
Old Jun 23, 2004 | 12:48 PM
my heads flow 275 at 600... he was runing it on a 355. but i no another guy that was runing a d1sc on a 383 a made 11 psi and his heads flow mid 250ish
Old Jun 23, 2004 | 12:52 PM
IDOXLR8's Avatar
they heads flow 275 at 600... he was runing it on a 355 but i no another guy runing a d1sc on a 383 a bade 11 psi and his heads flow mid 250ish
Huh ?
Sounds like your heads flow alot better than his so you will make less boost.
Old Jun 23, 2004 | 12:59 PM
RealQuick's Avatar
Originally posted by IDOXLR8
Huh ?
Thats what I was thinking too.
RUENUF
Mar 13, 2016 03:37 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
96SilverRam
Sep 7, 2015 10:51 PM
Henson071
Aug 4, 2015 09:32 AM
